Front brakes soft line help |
TonyA |
Feb 21 2024, 07:44 PM
Nachmal Group: Members Posts: 473 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Getting pissed again. I order stuff from so called reputable people and companies and keep getting the wrong parts. See the attached pictures. What is the proper length for the front brake rubber lines? The one set seems to be the correct length but the one end is not correct. The other line that I have has the correct ends but are too short.
Ishley |
Feb 21 2024, 08:20 PM
Member Group: Members Posts: 106 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
I had issues too. It turns out my 72 mid year car has a mix of old and new connection types. The 72 cars were transitioning some of the changes in Front A arms. This was the issue for me. I used PMB and we worked it all out when we talked thru it. They were great and took the wrong parts back with no issues.
bdstone914 |
Feb 21 2024, 11:08 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What year is your car? I think the early and laye fron fkex lines are the same lenght. The fitting end at the strut is different.
mlindner |
Feb 22 2024, 05:14 AM
Senior Member Group: Members Posts: 1,530 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I just installed new ones from PMB for my 74, perfect fit.
TonyA |
Feb 22 2024, 09:38 AM
I have used PMB, Auto Atlanta, Pelican, Stoddards and all with great success also. But my problem (and its me) is that I buy stuff way in advance and don't always check it. Then when its time to install and I find a problem I don't know who to blame. Moving forward I am not ordering stuff to far in advance, now that the supply chain has caught up. |
bdstone914 |
Feb 22 2024, 09:48 AM
I have used PMB, Auto Atlanta, Pelican, Stoddards and all with great success also. But my problem (and its me) is that I buy stuff way in advance and don't always check it. Then when its time to install and I find a problem I don't know who to blame. Moving forward I am not ordering stuff to far in advance, now that the supply chain has caught up. The short line may be a rear. Compare it to what is on the car. |
DRPHIL914 |
Feb 22 2024, 01:55 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have used PMB, Auto Atlanta, Pelican, Stoddards and all with great success also. But my problem (and its me) is that I buy stuff way in advance and don't always check it. Then when its time to install and I find a problem I don't know who to blame. Moving forward I am not ordering stuff to far in advance, now that the supply chain has caught up. The short line may be a rear. Compare it to what is on the car. (IMG:style_emoticons/default/agree.gif) i did the left side front and rear this last year, and if i remember correctly , looks like front vs rear for length. i did the group buy from PMB for the braided lines, since it had been almost 14 years since i bought the car and did them the first time. . i dont know about the differenced from year to year. Good luck hope you figure it out. Phil |
Lo-Fi Version | Time is now: 11th June 2024 - 01:28 AM |
