| morehills |
Feb 29 2024, 06:30 AM
Member ![]() ![]() Group: Members Posts: 134 Joined: 2-March 23 From: Great Barrington, MA Member No.: 27,202 Region Association: North East States
I'm doing a fairly large project on the interior of my 1971 914-6 GT clone this winter. I'm converting to 911 steering and ignition, adding a GT roll bar and harness mounts and a few other bits and bobs.
While it's open, should I cut an access panel? Is there any impact on the structural integrity of the firewall? How difficult is it to lean over the engine and adjust timing without the access panel? While it would be more convenient, I wonder if it's really needed to properly time the car every few years. It's a '71 2.2 liter "E" cam engine. Thanks for any advice. John Attached image(s)
| Cairo94507 |
Feb 29 2024, 06:43 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,609 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
If you have a factory 914-6, I would not cut the firewall; did not cut mine either. I have modded my 6 but the body is still essentially stock with the exception of my louvered front trunk floor to vent the oil cooler. I think the biggest hassle is if you need to change your fan belt or alternator. It can be done in the car, but it's a task best left to young, thin mechanics with long arms. The best plan for these cars is to just drop the motor for maintenance. Valve adjustment, address any leaks, new fan belt, etc. Timing them is a slight pain, but manageable with the engine in the car.
I think structurally, if you cut an opening in the firewall, make a nice metal panel that seals tightly when installed - maybe riv-nuts. I do not believe it is going to weaken the firewall. (IMG:style_emoticons/default/beerchug.gif) |
| gereed75 |
Feb 29 2024, 06:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
There are lots of threads and lots of opinions on this
http://www.914world.com/bbs2/index.php?showtopic=81727 Race car - absolutely. Street car ??? Remember, you have to cut fabricate fasten. For use you gotta remove seats and backpad. For me a “no”. For others a “why not”. Timing is not a big deal. For as much as these cars typically get driven, belts last a long time. Engine likely coming out for valve adjustment and other maintenance. Service the belt then. |
| Superhawk996 |
Feb 29 2024, 07:06 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
There are lots of threads and lots of opinions on this But only one right answer (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/stirthepot.gif) |
| brant |
Feb 29 2024, 07:24 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Drop the motor for valve adjustment
Geez. I do the valves 6-8 times every summer and never drop the motor for it |
| Superhawk996 |
Feb 29 2024, 08:29 AM
I haven’t read that thread in a while.
Here’s the thing that isn’t even discussed in that thread. An air cooled engine is way louder than a water pumper. OEMs go to great lengths to seal even the tiniest holes in a modern firewall? Why? NVH (Noise Vibration Harshness) It is amazing how much sound can be transmitted through even the smallest holes, unsealed weld seams, and past rubber grommets, and foam. All modern cars have multi layer NVH solutions to help quiet things down. But it all starts with minimizing protrusions through the sheetmetal. |
| Steve |
Feb 29 2024, 09:06 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I've had my 914-6 conversion since 1986 and only recently cut the firewall to replace the alternator with my 3.2. Otherwise getting to the belt, distributor and valves has never been a problem.
| Steve |
Feb 29 2024, 09:08 AM
I bought the PMS fiberglass cover, versus finding someone to cut up their firewall for a cover plate. https://patrickmotorsports.com/collections/...58367&_ss=r
| morehills |
Feb 29 2024, 09:25 AM
I bought the PMS fiberglass cover, versus finding someone to cut up their firewall for a cover plate. https://patrickmotorsports.com/collections/...58367&_ss=r Thanks for all the great replies and sorry to re-litigate this issue. So much good information here but it's sometimes hard to find. |
| gereed75 |
Feb 29 2024, 09:51 AM
Do my valves routinely in car also. I guess I was thinking about next time. Engine coming out for a bunch of other work.
Not sure there is a best answer for street cars. No in an original six, owner preferences on a conversion. I think if I were doing it I would maybe try to make a clean cut and then fab and weld in a bolt ring/flange and use the cutout to reseal the hole. |
| SirAndy |
Feb 29 2024, 10:28 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is there any impact on the structural integrity of the firewall? The clue is in the name ... Firewall Cutting a big hole in a wall that is supposed to protect you from an engine fire (to give you a few extra seconds to get out of there) is really only a good idea if you are prepared to deal with it in an emergency. (IMG:style_emoticons/default/popcorn[1].gif) |
| rgalla9146 |
Feb 29 2024, 10:47 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
IF you choose to put the access hole in, there is no better cover than a piece
cut out of a junked car . It will fit perfectly and look like it grew there. Timing and valve adjustment can be made much easier by marking your flywheel as done on original 914 6s Use the marks on your crank pulley to position the flywheel for marking. No need to be young, thin or acrobatic. Changing / adjusting your fanbelt is a challenge. Get the right tools. If using an aftermarket front mount be sure there is clearance to remove /install the V belt Practice replacing and adjusting before leaving on long journeys. |
| 930cabman |
Feb 29 2024, 10:57 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I cut mine for the /6 conversion. It's a simple patch to put things back together
| Superhawk996 |
Feb 29 2024, 11:17 AM
Ya all must be changing fan belts like underwear to need that much easy access.
I’m wondering how many of you are driving modern cars where you can’t even see the serpentine belt? (IMG:style_emoticons/default/idea.gif) |
| mlindner |
Feb 29 2024, 11:40 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,749 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
| brant |
Feb 29 2024, 12:10 PM
Ours
| Beach914 |
Feb 29 2024, 12:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,002 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California
I'm planning to do it on my GT conversion but will not even think of doing that on my -6 for obvious reasons.
I cut and saved a section from Frankencarcass back when I was parting it out. |
| dr914@autoatlanta.com |
Feb 29 2024, 12:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
NO WAY!!!!!!
I'm doing a fairly large project on the interior of my 1971 914-6 GT clone this winter. I'm converting to 911 steering and ignition, adding a GT roll bar and harness mounts and a few other bits and bobs. While it's open, should I cut an access panel? Is there any impact on the structural integrity of the firewall? How difficult is it to lean over the engine and adjust timing without the access panel? While it would be more convenient, I wonder if it's really needed to properly time the car every few years. It's a '71 2.2 liter "E" cam engine. Thanks for any advice. John |
| burton73 |
Feb 29 2024, 03:07 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,989 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
@morehills
I have what you want. I was going to put in my V8 car body but went a different route. I have 2, the bigger one may be better. Super clean part. I will list it in parts for sale. Best Bob B Burton Boxed in a 24x24x5 box. 10 lb for the big one as it cam from Garold a few years ago |
| 930cabman |
Feb 29 2024, 04:21 PM
Lo-Fi Version | Time is now: 2nd April 2026 - 01:35 PM |
