Side shift transmission console shift shaft plastic washers., Before I put this together I should replace them |
Shivers |
Mar 5 2024, 06:03 PM
Senior Member Group: Members Posts: 2,407 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Montreal914 |
Mar 5 2024, 08:13 PM
Senior Member Group: Members Posts: 1,568 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
r_towle |
Mar 5 2024, 08:46 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Reach out to Eric Shea at PMBperformance.com
Shivers |
Mar 5 2024, 09:00 PM
Mikey914 |
Mar 5 2024, 11:08 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Depending on the loading. It may be a good application for PTFE????
I do have these - https://914rubber.com/shift-guide-ring https://914rubber.com/shift-spring-guide-ring The larger one I'm not sure. |
Shivers |
Mar 6 2024, 08:08 PM
Depending on the loading. It may be a good application for PTFE???? I do have these - https://914rubber.com/shift-guide-ring https://914rubber.com/shift-spring-guide-ring The larger one I'm not sure. Thanks. These are a specific thickness. they seem to be a shim. They keep the shift shaft in the console from traveling too far so it stays ligned up with the rods. I was testing without these in and it got all fubar in the trans. Finally got the console out and had to use a screwdriver to move the rods back in place. Maybe I can find some brass at a hobby store and make some |
Krieger |
Mar 7 2024, 08:20 AM
Advanced Member Group: Members Posts: 4,721 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
@Dr Evil
TROJANMAN |
Mar 7 2024, 08:50 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
One of these? Pelican
Attached image(s) |
rhodyguy |
Mar 7 2024, 10:00 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
At $13 a set, I think 914rubber has it covered. They are often overlooked. No idea what one would do with blocks of Teflon.
Shivers |
Mar 7 2024, 10:09 AM
Shivers |
Mar 8 2024, 03:34 PM
Copper sanded to the correct thickness
Lo-Fi Version | Time is now: 28th May 2024 - 09:01 PM |
