914 Rear sway bar info, Rear sway bar install info |
porscheteck914 |
Mar 6 2024, 05:14 PM
Newbie Group: Members Posts: 30 Joined: 23-March 23 From: n.c. Member No.: 27,247 Region Association: North East States |
Hi ,Does anyone or this site have info or link, on how to install factory rear sway bar on car 1974 , that did not originally have a rear bar. How do you locate bar middle bushings ? What size bolts ? etc, etc. I bought a nice factory set up from Mark . Would like expert advice. Before I begin . Yes car already has front bar. thank you , Paul (IMG:style_emoticons/default/confused24.gif)
Montreal914 |
Mar 6 2024, 06:40 PM
Senior Member Group: Members Posts: 1,568 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
You need to install the mounting brackets under the car and also the trunk reinforcement plates in trunk (floor).
Here is the kit from Brad Mayer (no affiliation). Looks like it comes with instructions. https://914ltd.com/product/porsche-914-orig...way-bar-mounts/ This requires welding and protection of the metal after welding. Once this is done, you need to swap the lower shock bolts (something you probably figured out). Then install the bar. The drop links can require some force to pop onto the spheres but this can be achieved with a large C clamp. I know there are threads here somewhere. You will want to put grease in the drop link bushings. Another trick that was shared here is to drill a small hole in the center of the drop link bushings to allow air to escape as you are pushing them on the spheres. Hope this helps! Good luck with your project! (IMG:style_emoticons/default/smile.gif) |
Front yard mechanic |
Mar 6 2024, 07:31 PM
Senior Member Group: Members Posts: 1,167 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Montreal914 |
Mar 6 2024, 07:42 PM
BTW, photo shown above is of 75-76 car. Yours will be a little different but same concept.
rgalla9146 |
Mar 7 2024, 06:07 AM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Keep in mind there is curve in the arms of the sway bar. The curve 'droops' down not up. |
aturboman |
Mar 7 2024, 09:31 AM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
TargaToy |
Mar 7 2024, 11:44 AM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
porscheteck914 |
Mar 7 2024, 08:02 PM
Lo-Fi Version | Time is now: 29th May 2024 - 12:19 AM |
