Shredhead |
Member ![]() ![]() Group: Members Posts: 113 Joined: 10-August 15 From: CT Member No.: 19,047 Region Association: North East States ![]() |
I'm in the process of replacing side window seals and it appears that I can't unscrew the fuzzies rail with the window in place -- the screws are behind the window glass. Is that true and if so how do remove the window glass to access them?
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
You are correct. Depends on if you have the laye scissors, or worm drive.
Its pretty intuitive. There are other items that can be replaced too. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,737 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Your avatar looks like a 75 or 76, so scissor type. You need to strip the door basically. The window is basically the last item to come out. Even then you probably will have a fit removing that piece. The screws a very small Phillips head and will usually strip out when force is applied. sometimes you can reach the screw shank from behind with a pair of side cutters/dykes and get a grip to turn but otherwise you will need to drill them out with a small (3/32") bit. Small because you need to go back with another sheet metal screw and you don't want something with a large head that will negate the fuzzy strip protection. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 11th July 2025 - 03:36 AM |
