NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,416 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
Does anyone have pics of this part installed on the car, above and below? I am missing most of the 911 style accel cable parts for my 3.2 and want to see if this means not having to buy them. Like the $100 coat hanger, etc.
https://patrickmotorsports.com/collections/...63033&_ss=r |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,240 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Does anyone have pics of this part installed on the car, above and below? I am missing most of the 911 style accel cable parts for my 3.2 and want to see if this means not having to buy them. Like the $100 coat hanger, etc. https://patrickmotorsports.com/products/eng...31da9&_ss=r I have installed this on my /6 conversion with twin Webers. The core portion of the cable was about 1 1/2" too long and the connection at the rear might need a bit of attention. I can probably get some pics tomorrow Either way it looks much easier than the coat hanger/bracket affair. |
NARP74 |
I hope it is easier. I sent PMS a note and asked, they said I still needed all the 911 stuff. I asked for a pic and they said check the PET.
Better, I am checking with the real knowledge base! |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,926 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Is it this one? https://patrickmotorsports.com/collections/...63033&_ss=r
It looks like it just eliminates the bell crank, but still uses the coat hanger. The other link didn't work. |
NARP74 |
Yes. I fixed the original link.
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,628 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
@sirandy and A few of my customers use the long cable with no bell crank. If I were to do mine again I would use that cable for sure.
NARP74 |
@mb911 what parts do I need then? I seem to be getting differing info. Some say I need all the original parts, some say it bypasses them. Still need help.
mb911 |
@mb911 what parts do I need then? I seem to be getting differing info. Some say I need all the original parts, some say it bypasses them. Still need help. It bypasses all of it. You need a threaded ball cup on the end to operate the bell crank on the intake manifold and a way to secure the cable sheathing |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,311 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
@sirandy and A few of my customers use the long cable with no bell crank. If I were to do mine again I would use that cable for sure. Correct, i routed the cable in a loop in the back so it comes up through the back opening in the engine tine where the rod from the bell-crank would normally go through. The cable attaches directly to the throttle body on my 3.6L I don't think i have any good pictures of the setup, let me see what i can find. (IMG:style_emoticons/default/idea.gif) |
SirAndy |
Best i could find, the cable comes out of the firewall, goes under the engine and loops up through the opening in the engine tin and goes straight to the throttle body.
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1607107901.jpg) |
NARP74 |
A topside pic would be great if anyone has one.
SirAndy |
A topside pic would be great if anyone has one. All i got is this crappy pic (IMG:http://www.914world.com/bbs2/uploads/post-179-1629226390_thumb.jpg) |
930cabman |
Is it this one? https://patrickmotorsports.com/collections/...63033&_ss=r It looks like it just eliminates the bell crank, but still uses the coat hanger. The other link didn't work. Coat hanger not required with this cable. I will try to get a topside pic later. I have this cable installed, but shortened the core portion by 1 1/2" to get everything correct |
930cabman |
NARP74 |
I am getting closer, thanks for the help.
PMS was being lazy or snarky or both. The 1.5 inches too long is becoming a thing. Great topside pic. I will need several threaded ball cups and the rod on top. Now a good pic showing how the underside connection and adjustment are made. |
930cabman |
My experience with PMS has been they are OK and could use a bit of help with their customer service end of things.
Does the shot from below indicate what you are looking for? |
NARP74 |
My experience with PMS has been they are OK and could use a bit of help with their customer service end of things. Does the shot from below indicate what you are looking for? I can't exactly make out how and where the cable attaches under the tins. In the PMS pic, there is a CAD plated part that attaches somewhere and has a threaded adjustment barrel on it. Where does that go? How did you account for the 1.5 inches too long? I'll post some pics of what I have as well. Thanks again |
NARP74 |
NARP74 |
So the PMS part, a bracket, bolts to the trans just before the cable goes through the tins? Is that where a cable slack adjustment would be done?
Is the PMS cable considered a stock cable, like a 914/6 or 911 cable? Or is it custom. I think it was Brant that mentioned the benefit of using stock parts that could be borrowed in a crunch. |
930cabman |
So the PMS part, a bracket, bolts to the trans just before the cable goes through the tins? Is that where a cable slack adjustment would be done? Is the PMS cable considered a stock cable, like a 914/6 or 911 cable? Or is it custom. I think it was Brant that mentioned the benefit of using stock parts that could be borrowed in a crunch. Correct, the bracket furnished with the PMS cable attached to the trans bolt and there is a small adjustment available there. From what I can tell it's a custom product, after shortening the core about 1 1/2" it seems to be working fine. Time will tell |
Lo-Fi Version | Time is now: 2nd September 2025 - 07:28 PM |
