Dash instruments, refurbishment |
slotty008 |
Mar 24 2024, 08:55 AM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
I finally found a solution to make the instruments look like new again. The bezels looked awful but I couldn't find the right size. The one I found for the tachometer now is not ideal because it"s a VDO Viewline bezel for boat instruments . It's thicker and I had to paint it semigloss black because it's plastic. But I think it will look good once installed . I'm just waiting for a piece of plexi that I ordered to change the lens, because it was damaged also. One of the PO's didn't do a very good job .
The other two bezels will be better because I found the right size and shape in Hungary.(on eB) They are VDO but advertised for a Wartburg but they are exactly the same as the 914's. |
slotty008 |
Mar 24 2024, 08:57 AM
Montreal914 |
Mar 24 2024, 09:34 AM
Senior Member Group: Members Posts: 1,568 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Maybe place a WTB add for the tach bezel?
Why use plastic instead of glass for the gauges? (IMG:style_emoticons/default/confused24.gif) |
slotty008 |
Mar 24 2024, 09:46 AM
Maybe place a WTB add for the tach bezel? Why use plastic instead of glass for the gauges? (IMG:style_emoticons/default/confused24.gif) The lens inside was also plastic ,probably put in by one of the PO's, but when I took the the left gauge apart I saw it was glass. Offcourse glass is stronger but when it's cold and damp outside, the glass get's fogged from the inside. Don't ask me how it's possible because the left gauge has never been taken apart before. |
slotty008 |
Mar 24 2024, 09:51 AM
But then I don't live in Calfornia, but in Belgium, and it has been raining here almost every day for the last six months.
Shivers |
Mar 24 2024, 01:02 PM
Senior Member Group: Members Posts: 2,407 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Chris914n6 |
Mar 24 2024, 02:35 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
^^ they have the bezels made for them.
Plastic was used in 75-76 instead of glass cuz cheaper. Pelican used to sell the glass for a nice markup. Glass places can cut you one if you bring the original in for measuring. |
Lo-Fi Version | Time is now: 28th May 2024 - 11:27 PM |
