WTB : 914 Instrument gauge indicator lenses, Instrument cluster indicator lens / Yellow / & red |
porscheteck914 |
Apr 6 2024, 02:17 PM
Newbie Group: Members Posts: 30 Joined: 23-March 23 From: n.c. Member No.: 27,247 Region Association: North East States |
Hi , Does anyone know were I can get the little indicator plastic lenses that go in the temp /oil gauge, The line of them across a 1974 gauge. Looking for yellow , mines dry rotted/faded. Also looking for the other colors too . Thank you very much . Paul
914Sixer |
Apr 6 2024, 03:43 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
NO longer available new.
FlacaProductions |
Apr 6 2024, 03:45 PM
Senior Member Group: Members Posts: 1,607 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
That's a tough one.
I've rebuilt a few of the combo gauges using lenses I found scavenging from other gauges. I've seen versions where just appropriately colored lenses are glued across the back of the gauge face - giving you the correct coloring but not the correct lens appearance. Looks pretty good, though. You can find colored acrylic sheets/rounds on ebay or amazon. @burton73 and I talked a lot about this - to the point where he hand poured me some (that's his field) that I ended up hand-finishing and they look pretty good - but labor intensive for sure. maybe he'll chime in here. |
Mikey914 |
Apr 6 2024, 05:04 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
May have some I can check Monday when I'm back in. Pretty sure I do. If so, they're yours as I think I had a bunch.
FlacaProductions |
Apr 6 2024, 05:41 PM
And that "yellow" one is supposed to be white and is a dummy with no backlight. I also believe it's shallower than the red and green as it doesn't fit into a rubber light tube - it's just taped to the back of the gauge face.
burton73 |
Apr 6 2024, 10:33 PM
burton73 Group: Members Posts: 3,539 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
That's a tough one. I've rebuilt a few of the combo gauges using lenses I found scavenging from other gauges. I've seen versions where just appropriately colored lenses are glued across the back of the gauge face - giving you the correct coloring but not the correct lens appearance. Looks pretty good, though. You can find colored acrylic sheets/rounds on ebay or amazon. @burton73 and I talked a lot about this - to the point where he hand poured me some (that's his field) that I ended up hand-finishing and they look pretty good - but labor intensive for sure. maybe he'll chime in here. Sorry I just trashed the small test mold I made for this. No Idea where you can get them as a stock piece Best Bob B |
burton73 |
Apr 6 2024, 10:34 PM
Sorry
porscheteck914 |
Apr 12 2024, 01:01 AM
Mikey914 |
Apr 13 2024, 12:51 PM
I'll head out to the barn tomorrow again. I shuffled some parts, pretty sure I do, but will confirm tomorrow.
Mark |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:56 AM |
