FS 1970 Tangerine 914, Olympia, WA |
tvdinnerbythepool |
Apr 18 2024, 01:09 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Listed my car a few places but here is a link to the CL listing
If you guys know of anyone who may be interested feel free to reach out. I’ve had some interest and lots of complements but no takers quite yet. $19k. No shipping or trades https://seattle.craigslist.org/oly/cto/d/tu...7747033492.html Attached thumbnail(s) |
TROJANMAN |
Apr 18 2024, 01:50 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Looks nice. GLWTS
Mikey914 |
Apr 27 2024, 09:50 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have seen this car. It's really pretty well sorted out and would offer an excellent 1st car without any real work to be done for quite some time. @tvdinnerbythepool may want to link in some of your threads.
maj75 |
May 4 2024, 04:37 PM
Member Group: Members Posts: 69 Joined: 26-May 20 From: Lighthouse Point, FL Member No.: 24,317 Region Association: None |
Curious, why no shipping? I’d be interested, but I’d need the car shipped.
mepstein |
May 4 2024, 04:45 PM
914-6 GT in waiting Group: Members Posts: 19,312 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Curious, why no shipping? I’d be interested, but I’d need the car shipped. Usually it means the seller won’t set up shipping. I’m guessing once it’s paid for, he won’t care who picks it up. But if you are a buyer for the car, call the seller and talk. A phone call usually gets everyone on the same page pretty quickly. Great looking car. (IMG:style_emoticons/default/beerchug.gif) |
914_Tcup |
May 5 2024, 10:22 AM
Newbie Group: Members Posts: 18 Joined: 24-November 23 From: T-Town (Tulsa OK) Member No.: 27,754 Region Association: Southwest Region |
Curious, why no shipping? I’d be interested, but I’d need the car shipped. Usually it means the seller won’t set up shipping. I’m guessing once it’s paid for, he won’t care who picks it up. But if you are a buyer for the car, call the seller and talk. A phone call usually gets everyone on the same page pretty quickly. Great looking car. (IMG:style_emoticons/default/beerchug.gif) Agreed! (IMG:style_emoticons/default/smilie_pokal.gif) |
tvdinnerbythepool |
May 28 2024, 06:52 AM
Hey guys, Not trying to be a pain with the no shipping. It just really want the buyer to come and see the car in person so they know exactly what they are getting. I just don't want to ship someone a car they haven't seen.
Update from the last time it was posted, I came across a rebuilt by Bosch ECU from the early 80s (and then sat on a shelf for 40 years) and holy cow did it solve some long issues with starting and idle. I went through 4 ECUs before this one with no help. Starts first time! Anyway, hope to find her a good home for a reasonable price this summer. |
tvdinnerbythepool |
May 28 2024, 08:49 AM
Below are all the items that have been replaced, rebuilt, restored, rejuvenated etc since car was purchased in 2018
-New (remanufactured by Bosch) ECU! Runs really well -Wiring harnesses for Engine and Ignition (Jeff Bowlsby and 914rubber) -123 Distributor -Coil, Spark Plugs and Wires -"Hell Hole" Battery Tray and Right side Engine Tray Sheet metal (Longs look great see pics) -Thermostat, Thermostat Cable -Cylinder Head Temp Sensor -o2 bung welded onto exhaust for tuning -Stainless Fuels lines front to back (plastic lines removed) -Modern fuel pump relocated to front trunk -Fuel tank sock -Fuel Filter -Throttle Cable -Shifter bushings front to back -Engine Seals replaced -Vacuum lines front to back -Engine bay rain tray (914 Rubber) -Trickle Charger -Front and Rear Rotors and Pads -Front and Rear Rebuilt Calipers -19mm Master Cylinder -Rubber brake hoses -Rear Suspension, 914rubber Springs, Bilstein Struts, 914rubber Trailing Arms and Bushings -Front Suspension 914rubber Bushings and Bilstein Strats -Tie Rods -Front and Rear wheel bearings -Electric washer fluid pump conversion and lines -Targa Top Seals (914 Rubber) -Pedal cluster wooden board -Transmission flush -Speedometer Input Shaft and Seal kit (914rubber) -Stainless Wheels with 914 Hub Caps (Original Rivieras included) -Plastic dash cover -Carpet set (not installed) -Custom 914 embroidered floor mats -Door Panels (914 Rubber) -Sun visors -JVC BT Stereo with 4 Rockford Fosgate Speakers, 914rubber speaker housings, Microphone and Blaupunkt Subwoofer -Cellphone holder (Modded ash tray with cell phone holder) -Center Console with Speakers, Cupholder and Sub Control (Not OEM, All removable) -Cigarette lighter/12v power outlet -LED bulbs for gauges -Turn signal lenses -Dome light lens and switch -Door switches for dome light -Car Cover Rebuilt/Replaced -Rebuilt Brake Calipers -Replaced AAR Valve -Rebuilt Manifold Pressure Sensor (Tangerine Racing kit, now tunable on car with o2 sensor) -Rebuilt Pedal Cluster with Brass Bushings -CV joints serviced with safety wired bolts -Converted to later model air intake with paper gasket (Original oil air filter housing included) -Bursch Exhaust -Driver door deposit box sourced and installed -Valves adjusted (Fall '23) and fresh valve cover gaskets Michelin 195/60R15 with lots of life left Compression Checks #1/120 #2/128 #3/125 #4/135 Let's talk about Rust. When I got the car the battery tray and hell hole were a mess! That sheet metal was cut out, everything rotten got fresh sheet metal, por15 and painted to keep it sealed. There was a hole under the right rear where the prior owner thought the jacking location was. That was cut out repaired/treated and sprayed with under coating to protect. There was also a small hole in the passenger side jack side post due to a missing cover and water/debris getting in there and getting stuck. That was repaired too. The passenger long which is the one that is notoriously problematic is in really nice shape as pictured. There was some surface rust in both trunks so I sanded, treated and painted those. Little bit of surface rust under the pedal cluster from 50 years of wet feet and a wooden board holding the moisture. That was taken down to bare metal and also given the POR15 treatment. I will not say this car is "no rust"...i'm just not aware of any rust that hasn't been addressed already. What’s left? It's not a perfect car. It is 53 years old with fuel injection from the 1960's! At some point the seats could use some new covers. I have recovered (over the original material) the seat bottoms, easily removed. The paint has some imperfections but overall still shines and looks great! It is a repaint of the original tangerine, not sure from when. It is smothered in wax and comes with a cover to keep it protected! |
Lo-Fi Version | Time is now: 6th June 2024 - 12:51 PM |
