| doug_b_928 |
Apr 24 2024, 07:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 743 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Does anyone know where I can get the nut (113 955 481) that holds the washer fluid line to the bottom of the reservoir? I tried the local Porsche and VW dealerships and nada. The part number comes up in a few places in Europe but I'm hoping it's available in North America. I'd have thought it would be on CiP1 but it didn't come up when I searched there. Here's an image of what comes up under the part number:
![]() Also, does anyone know if the hose at this connection had an expanded end on it so that the nut will hold it onto the nipple? It doesn't look like it in the PET diagram, shown below: Here's an image of my tank with the line on it. It does look like the hose expands over the nipple so does the nut hold it on without a flange on the line because the hose is expanded over nipple? ![]() |
| dr914@autoatlanta.com |
Apr 24 2024, 10:31 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,250 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
of course at LEAST 50 (used) in stock
Does anyone know where I can get the nut (113 955 481) that holds the washer fluid line to the bottom of the reservoir? I tried the local Porsche and VW dealerships and nada. The part number comes up in a few places in Europe but I'm hoping it's available in North America. I'd have thought it would be on CiP1 but it didn't come up when I searched there. Here's an image of what comes up under the part number: ![]() Also, does anyone know if the hose at this connection had an expanded end on it so that the nut will hold it onto the nipple? It doesn't look like it in the PET diagram, shown below: Here's an image of my tank with the line on it. It does look like the hose expands over the nipple so does the nut hold it on without a flange on the line because the hose is expanded over nipple? ![]() |
| doug_b_928 |
Apr 24 2024, 11:00 AM
Excellent, George. Do you know if the line needs a special end?
| doug_b_928 |
Apr 25 2024, 07:16 AM
Does anyone know if a flanged hose end is needed in this location?
| maze914 |
Aug 4 2024, 09:00 AM
Newbie ![]() Group: Members Posts: 5 Joined: 4-August 24 From: Canada Member No.: 28,272 Region Association: None |
I have the same question. If you watch the attached video it looks like there is no special end on the hose. I'm going to try this connection this weekend, will post a photo and notes if it works.
https://www.youtube.com/watch?v=vX3ql9kTEhc 5:18 minutes on the video shows him taking the line off the water bottle nipple. |
| Montreal914 |
Aug 4 2024, 09:46 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,214 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
A couple more options for you. (IMG:style_emoticons/default/smile.gif)
Air heads: https://airheadparts.com/vw-part/washer-hos...sed-113-955-481 Bus Depot: https://www.busdepot.com/113955481 |
| maze914 |
Aug 5 2024, 08:56 AM
just installed the hose onto the bottle, with the nut. Can 100% confirm there is no other item needed except your washer line hose and the nut. It takes a bit to get the hose through the nut. Once you have it through the nut just pull enough through the nut to land it on the nipple and then tighten the night, which will secure the hose. I used some hand sanitizer to lube the hose so it slide easier, worked great. Here are the photos.
Attached thumbnail(s) Attached image(s)
| doug_b_928 |
Dec 11 2024, 11:40 AM
Just seeing this reply now (the lack of email notifications is a bummer). Thanks so much for taking the time to reply and for confirming how it works!
| 56kabrio |
Dec 11 2024, 01:48 PM
Member ![]() ![]() Group: Members Posts: 66 Joined: 1-December 05 From: Framingham, MA Member No.: 5,219 Region Association: None
Just seeing this reply now (the lack of email notifications is a bummer). Thanks so much for taking the time to reply and for confirming how it works! Here’s a link to VW Classic Parts for a new one. https://www.volkswagen-classic-parts.com/ca...4WEz4pxr0EMOurY Hope this helps. Mack |
Lo-Fi Version | Time is now: 2nd November 2026 - 01:11 AM |
