Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,385 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
We are having an issue finding 50mm ducting (hose) to go from the "mouse ears" to the heater flapper. What we have is the rather inexpensive cardboard tubing available pretty readily. I am looking for something that is almost a plastic coated duct hose that would withstand dirt and possible....getting wet, and be able to keep clean. We have some in 60mm that is the finish we want, it's just too big.
We have searched high and low and came up scratch. I did find some 50mm plastic hose in the UK, but it only comes in 300mm/30cm (11.81 inches) lengths. I really need something that is 30 inches, 76.2cm or 762mm. Anyone have a suggestion? Thanks all, Michael (IMG:style_emoticons/default/beerchug.gif) |
56kabrio |
Member ![]() ![]() Group: Members Posts: 65 Joined: 1-December 05 From: Framingham, MA Member No.: 5,219 Region Association: None ![]() ![]() |
We are having an issue finding 50mm ducting (hose) to go from the "mouse ears" to the heater flapper. What we have is the rather inexpensive cardboard tubing available pretty readily. I am looking for something that is almost a plastic coated duct hose that would withstand dirt and possible....getting wet, and be able to keep clean. We have some in 60mm that is the finish we want, it's just too big. We have searched high and low and came up scratch. I did find some 50mm plastic hose in the UK, but it only comes in 300mm/30cm (11.81 inches) lengths. I really need something that is 30 inches, 76.2cm or 762mm. Anyone have a suggestion? Thanks all, Michael (IMG:style_emoticons/default/beerchug.gif) Michael Found this ad in the UK. Sold in 23 meter roll. https://www.autosiliconehoses.com/pvc-corru...m-23-metre.html Hope this helps. Mack |
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,852 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
@Cairo94507
50 MM is 1.9685 inch very close to 2 inch. Aeroduct Ducting www.wicksaircraft.com Take a look. You are very close to getting this. Best Bob B |
Cairo94507 |
Hi Bob & Mack,
It looks like Bob's referral is available in the length I need for a not ridiculous price. I just need to verify with Greg that that will work. But, it does look like what we need. Cheers, Michael (IMG:style_emoticons/default/beerchug.gif) |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Mack's hose is rated to 55c or 131F. Not high enough IMO for the application.
Running would work fine due to the cooling air but shutdown "heat soak" might hurt it. Bob's suggestion is a mere 1/32 of an inch too BIG. I didn't check heat rating on it (you should) but if a "tiny bit too big" won't work I'd be surprised. |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,974 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Seems to me there was a NAPA hose that was nearly identical to stock. I don't recall more than that.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,169 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Seems to me there was a NAPA hose that was nearly identical to stock. I don't recall more than that. I used the NAPA hose recently and it worked perfect. I will look around later and see if I can find anything. A search for this took me quite a while, and I might have saved the tag, somewhere. It took the guys at NAPA awhile to find it in their system, might be called "defroster hose" |
RAX914 |
Member ![]() ![]() Group: Members Posts: 109 Joined: 20-August 14 From: California Member No.: 17,801 Region Association: None ![]() ![]() |
Aircraftspruce.com:
https://www.aircraftspruce.com/catalog/appa...?clickkey=77121 They also have it in black |
slowrodent |
Member ![]() ![]() Group: Members Posts: 195 Joined: 29-February 20 From: Tucson/Oro Valley Member No.: 23,981 Region Association: Southwest Region ![]() ![]() |
Bunch on eBay right now as 2” defroster hose. Just saying
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,864 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Isn’t that aero ducting too stiff? Seems like every time I see it used it bends only on one spot instead of making a nice natural bend along the whole way. (IMG:style_emoticons/default/confused24.gif)
Cairo94507 |
Thanks to all who helped move this ball down the field. I now have several options and the next time Greg and I meet, maybe tomorrow, we can discuss them and see which way we go. For now though, we can use the 50mm cardboard stuff as it will be easy to swap once the motor is in the car. (IMG:style_emoticons/default/beerchug.gif)
technicalninja |
I've never seen the cardboard stuff fail due to heat.
It can get old and delaminate, but heat doesn't seem to mess with it. |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,610 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Wag aero group sells it. I bought some off Amazon it’s labeled sceet or scat tubing.
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,416 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
technicalninja |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
Yes, check that OUT! I know what I'd use. 572F working temp! Water resistant! (I was going to mention the cardboard stuff probably shouldn't get wet) Got a "German" look to it... But the absolute most "KILLER" thing about is the inner sheath... This is a BIG problem with brake ducting hoses. The ones with the corrugated inners decrease flow BIGTIME! A 2" hose is the equivalent of a 1.5" with the ribbed inner surface. That has a nice sleeve! I know what I'll use from now on for brakes duct hosing! Reasonably priced as well. @Luke M (ok how can I tag "Luke M") You kick ass Sir! Thanks for that link |
NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,380 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
@Luke M quotes around the user name with spaces etc.
Luke M |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) Yes, check that OUT! I know what I'd use. 572F working temp! Water resistant! (I was going to mention the cardboard stuff probably shouldn't get wet) Got a "German" look to it... But the absolute most "KILLER" thing about is the inner sheath... This is a BIG problem with brake ducting hoses. The ones with the corrugated inners decrease flow BIGTIME! A 2" hose is the equivalent of a 1.5" with the ribbed inner surface. That has a nice sleeve! I know what I'll use from now on for brakes duct hosing! Reasonably priced as well. @Luke M (ok how can I tag "Luke M") You kick ass Sir! Thanks for that link Glad to help out. I'm laid up for a bit til I get an MRI done and see the Dr. so shopping online is what I'm doing.. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/type.gif) |
Cairo94507 |
@Luke M - Thanks for that link. I think that may be the winner. I will talk with Greg tomorrow when we get together and if that passes his review, that is what I will order. Thanks a lot for the help everyone. It takes a freakin' village for sure. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 15th July 2025 - 03:18 AM |
