hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 628 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
I had my seat belts re webbed by Seat Belt Planet and installed them today. Looking at the way I installed them gets me wondering if I put them in correctly. Also seems like They should be tighter on the bolt. I can move them (no not swivel to put them on) back and forth. In the pic you can see space between the spacers and belt hardware.
Any ideas appreciated. Thanks Renee ![]() |
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,492 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Just went through a similar saga. For once, the PET wasn’t that helpful. The major point is to make sure that the bolt can be tightened against washers or sleeves all the way to the frame. You want to be able to put torque on the bolt and still be able to swivel the belt guide.
hndyhrr |
Just went through a similar saga. For once, the PET wasn’t that helpful. The major point is to make sure that the bolt can be tightened against washers or sleeves all the way to the frame. You want to be able to put torque on the bolt and still be able to swivel the belt guide. Thanks I pulled the bolts out they were tight. The bolt in the top was all the way in couldn't go any further. Still had slop. The bolts are two different lengths. maybe i got the wrong bolt in the wrong hole? These are the bolts that have been in the car since birth. lol |
windforfun |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,057 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
I had to reattach my mounts after I replaced the pads. I'll take some pics mañana to give you some accurate info. The left & right bolts are the same in length. |
windforfun |
Here you go. This is the stock arrangement. Tomorrow comes too quickly when you get old.
Attached thumbnail(s) ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,048 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I had my seat belts re webbed by Seat Belt Planet and installed them today. Looking at the way I installed them gets me wondering if I put them in correctly. Also seems like They should be tighter on the bolt. I can move them (no not swivel to put them on) back and forth. In the pic you can see space between the spacers and belt hardware. Any ideas appreciated. Thanks Renee ![]() Does not look correct. I can lay out the correct order of parts tomorrow and post a picture. That bolt is the longest. There are three different lenghts. You should have the metal spacer sleeve last on that bolt |
hndyhrr |
I had my seat belts re webbed by Seat Belt Planet and installed them today. Looking at the way I installed them gets me wondering if I put them in correctly. Also seems like They should be tighter on the bolt. I can move them (no not swivel to put them on) back and forth. In the pic you can see space between the spacers and belt hardware. Any ideas appreciated. Thanks Renee ![]() Does not look correct. I can lay out the correct order of parts tomorrow and post a picture. That bolt is the longest. There are three different lenghts. You should have the metal spacer sleeve last on that bolt please and thank you |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,868 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
hndyhrr |
Lo-Fi Version | Time is now: 19th July 2025 - 03:23 AM |
