Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Just ordered a Eurorace header (now European Motorworks).....so now I need to search for a muffler.....I've heard the single chamber Flowmaster that is running on "Julius" and I'd like something a little quieter.......huh??
For you smart-asses out there...yes, this time I am getting a real header, not a Bursch without the muffler (IMG:style_emoticons/default/ohmy.gif) |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,635 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
I have a full-size Flowmaster 40-series Delta Flow on my eurorace header. It's a 2" inlet/outlet that is attached via a short stub tube with the 3-hole flange welded on.
It exits straight out back from the collector (no bends) and is hanging from a mount attached to the trunk bulkhead/firewall. It is still very loud under heavy throttle, but probably not quite as much as the tiny drag-race Flowmaster Brad used. At idle and cruise it is pretty mellow and tolerable. Jegs (www.jegs.com) has the full range of Flowmasters in just about every size and noise-level desired. They are around $70/ea. |
jonwatts |
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 ![]() ![]() |
Dude, you're a glutton for punishment bringing that up again.
Mueller |
I'm ignoring you Jon, (fingers in ears...lalalalalala)
Speaking of exhausts and such...Pete Weber, wrote this that is a good read: Pete Weber article |
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
Mike
I've got a Flowmaster 40 series Delta Flow muffler as well. 2" center inlet, 2" offset outlet. Welded onto a Bursch style collector with SS heat exchangers. Works well, fairly loud. I would have preferred to use a 50 series Delta Flow instead for a little more mellow sound, but it was 4 inches longer than the 40 series and wouldn't have fit. Demick '74 2.0 |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Chris Farley Racing, LOL!
Maybe I should change the name... |
Lo-Fi Version | Time is now: 19th July 2025 - 03:04 AM |
