bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
not dizzy, not pre-ignition....(present in all extremes of timing)
what in the world could this be? did i snap a piston ring or something, is it piston slap, engine ticking until it goes KABLOOM or what? sounds like someone put a nut in the fan and its goign clak clak somewhere...under moderate acceleration.. seems vibration related really, as when i first let out on the clutch i hear it for a second. |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
this may seem whacked, but check the brake lines at the firewall where the perportioning valve is. I had one line that vibrated against the firewall at certain RPMS and load conditions and made a sound like you are describing.
Gary# |
Member ![]() ![]() Group: Members Posts: 217 Joined: 15-May 05 From: Buena Park, Ca. Member No.: 4,078 ![]() |
That happened to me too - (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
I removed my wife from the trunk & the strange noise stopped. (IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif) |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
maybe you are running too lean from feeding your engine through a fucking straw... (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
is there a "pinging" sound? loose valves? when was your last valve adjust? did your VW mecahinc friend do it? (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) i HIGHLY DOUBT you sontaneously dropped a piston ring or a wrist pin... but with you, who knows? did you do a compression check? do you know HOW to do a compression check? help us out here... we can't heard it over the net through your post... or take it to a real mechanic that KNOWS type 4s... not just type 1s |
bd1308 |
that's what i'm doing. i'm finished messing with the dumb car....
scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
check you engine and tranny mounts, and while under there take a small rubber hammer and hit the tins, HE, every thing that can move or viberate. does the sound come from the middle of the car, back ???. i wonder if your throw out bearing is going bad ie, the sound when you let off the clutch
tat2dphreak |
it could be 1000 things with the descriptions used... things do get loose on 30+ year old cars...
bd1308 |
engine mounts are okay---
one tranny mount was kinda ugly...but still held. i hear ya, i know i'm being stupid here by asking what a rattle sound is.... i'll just take it to the mechanic, the porsche one. |
tat2dphreak |
a p-car mech may not know t4s either... oh nevermind... |
bd1308 |
naw, this guy is good.
he's kinda far away, but he AX'd 914s in the 70s and 80s.... he has a 914/6 he's done many restorations on 914s, complete tear-downs and what-have-you. |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
Pebbles in the melon? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
bd1308 |
oh my....That's it....I beat my head against the wall and it made the same sound... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
tat2dphreak |
I was thinking it was a "loose nut behind the wheel" (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
brain rattling around in your head? or the gears in your mind that need lubing....
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Just keep doing what you are doing it will stop. |
Lo-Fi Version | Time is now: 17th June 2024 - 12:59 PM |
