> Cheap paint
post Aug 15 2024, 11:13 AM
914-6 GT in waiting
Interesting thread on pelican by a long time poster who knows a lot about painting cars and used to own a successful paint shop.
https://forums.pelicanparts.com/paint-bodyw...cost-paint.html
Replies(1 - 19)
Root_Werks
post Aug 15 2024, 11:17 AM
Village Idiot
Eh, even if I was going to paint my 30 year old Ford Ranger, I'd drop the coin on decent paint. You're not saving that much.
Looks nice, wonder how long it'll last?
Superhawk996
post Aug 15 2024, 11:31 AM
Suspect it will last as long as any enamel paint from 80s - 90s. Meaning Decades as long as the prep was well done.
Tons of teeners out there running around with 80s and 90s enamel respray jobs.
Not a bad way to go if you just want cheap paint. Might do something like that for my old 92’ Mazda b2600 that is currently two colors due to a bed swap.
post Aug 15 2024, 11:41 AM
914-6 GT in waiting
What little I know about paint, any kind of paint, is that prep is 95% of the job.
Mowog4
post Aug 15 2024, 11:42 AM
I decided to paint my Bugeye Sprite myself (my first paint job in 30 years), I bought a gallon of base coat and a gallon of clear and was all in for less than $1000. I needed the gallon cause I kept screwing it up, but it came out nice.
930cabman
post Aug 15 2024, 03:51 PM
QUOTE(mepstein @ Aug 15 2024, 11:41 AM) *
Sure, the quality of the finish product is important, I will be using this: https://paintforcars.com/product-category/a...AMaAgaUEALw_wcB
About 60 - 70% done with prep and will soon know how Paintforcars performs
JeffBowlsby
post Aug 15 2024, 04:35 PM
I rather doubt that "all enamel paint is the same". Dr Google says:
"Type of Enamel: Enamel paint comes in two types: oil-based and water-based. Oil-based enamel is harder, but it requires mineral spirits to clean nup. Water-based enamel, however, is less durable than oil-based enamel, making it unsuitable for high-traffic areas. Choose the enamel paint based on your desired finish."
"The term "Enamel" covers a wide range of paint materials over as many years as automobiles have been around.
Pyroxoline Enamel (early finishes)
Synthetic Enamel (Alkyd Resin) fleet finishes, still in use today.
Synthetic Enamel With a hardner.
Acrylic Enamel (late 50's)
Acrylic Enamel With a hardner (70's), Polyurethanes
Urethane Enamels (true urethane resin technology)"
"The difference? In layman's terms, longevity and durability. Urethane will last longer (hold it's shine) longer than enamels for the most part. BUT....enamels are a little more forgiving of marginal prep. BUT....urethanes are easier to fix if you screw up. BUT enamels are a little less expensive."
"In typical fashion, enamel paints are used to describe oil-based covering products, usually with a significant amount of gloss in them, however recently many latex or water-based paints have adopted the term as well. Enamel means “hard surfaced paint” and usually is in reference to paint brands of higher quality, floor coatings of a high gloss finish, or spray paints. Most of the paints are alkyd resin based, however some have been made by adding varnish to oil-based paints."
930cabman
post Aug 15 2024, 05:08 PM
QUOTE(JeffBowlsby @ Aug 15 2024, 04:35 PM) *
So far as I know originally our 914's were painted with straight enamel.
I was wrong once, but it was a long time ago
post Aug 15 2024, 07:21 PM
I used their enamel on my two tone front bumper and it flows out great. I added extra hardener since it is the front bumper and sits low to the ground. That was about 4 years ago & it is still in great shape. And no chips from road debris. (IMG:style_emoticons/default/beerchug.gif)
Front yard mechanic
post Aug 15 2024, 08:13 PM
I painted my little Toyota truck the same way. The work is all in the prep. And it turned out really nice but the paint looses its shine in the sun. I got about two years out of it now I’m ready to cut it and try to bring the shine back up. Wish I would have used a higher quality paint.but I do believe it makes a durable thick finish. If it doesn’t last this time I’m going to find a material I can go straight over itAttached Image
bkrantz
post Aug 15 2024, 09:21 PM
And Earl Scheib used to paint cars for $29.95 ($99.95 in the 1980s).
There are always ways to do something sorta like what you want for a given price.
But how much for an actual commercial paint job (with a minimum amount of prep) that most people would consider decent? I say $5000 to $6000 or more.
MikeK
post Aug 16 2024, 11:03 AM
I've been using the Summit line of primers lately, both epoxy and 2K. A great product at a great price.
I've yet to use their line of paints, though I would assume that they are every bit as good as the primer offerings. They have quite a few standard colors, so if you're not getting a custom-mixed color, it's and inexpensive way to paint a single-stage urethane.
I use alkyd paints, like the ones the guy sprayed his truck with, on engine tin, wheels and smalls, but I wouldn't be too keen on shooting a whole car with it. Prepping is very time consuming and it would be worth it to me to spend just a little more money on a quality paint. A gallon of epoxy, a gallon of 2K and a gallon of paint would likely still be under $500.
VaccaRabite
post Aug 16 2024, 02:17 PM
En Garde!
Several years ago I painted a guys M!008 CUCV pickup pickup in epoxy sold through a milsurp shop designed for old Jeeps and military trucks. It looked and smelled JUST like Rustoleum, and the suggested primer was a Rustoleum product - though this paint was a different brand.
It looked GREAT when I painted it, given that the guy stressed that I do minimal prep.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1723839437.1.jpg)
But after about 2-3 years of being kept outside the paint was definitely faded and sunburned.
in 2020 I used Rustoleum hunter green to paint my little m416 trailer, and it also lives outside and the paint has held up GREAT. No real fading and sunburn, and it also lives outside all the time for about 4 years now.
A gallon of Rustoleum is CHEAP compared to any 2K paints, but I still don't know that I'd want to paint a sportscar with them.
Zach
DennisV
post Aug 16 2024, 02:34 PM
QUOTE(bkrantz @ Aug 15 2024, 08:21 PM) *
Depends greatly on your definition of "decent". As of 2024, if you call folks on US West coast that are known for shooting Porsche cars, they are quoting $30k and up. Minimum 1 year wait list. That's strictly for priming and painting. No metal work.
BTW - There's probably no warranty on that job either, as they can't be sure of the integrity of the epoxy primer job that you or your body guy applied.
windforfun
post Aug 16 2024, 03:52 PM
QUOTE(DennisV @ Aug 16 2024, 01:34 PM) *
That sounds about right. You sort of get what you pay for these days.
slowrodent
post Aug 16 2024, 04:14 PM
I've had some bad experience using inexpensive automotive enamels and other cheap enamels with regards to chemical resistance (mostly just gas).. I wouldn't mess with putting paint on a car/bike that was not at least acrylic. My DIY car body paint these days is all 2k. (Also, I've found that the 2k clears in spray cans work great)
Unobtanium-inc
post Aug 16 2024, 10:15 PM
I've painted several Porsche over the years and painting well is really hard. I asked the guy who painted my 356 about this and he said, "it's the dozen".
He said there are about a dozen things you have to get right to get a good paint job and your average guy who knows tools can count on getting about 8 right on any given paint job. This corresponded with what I was getting, a different problem every time, sometimes this, sometimes that, but never a perfect paint job. He said you really need to have painted about 100 cars in a few year period to get to the 12, where the paint gun becomes part of your arm.
This was my last paint job.
Ishley
post Aug 18 2024, 10:08 AM
I painted my car. I used a lot of Eastwood primers, Bondo, highbuild etc. I stripped my car back to bare metal and worked forward from there.
You need a good air filtration system to keep the water out no matter what you do. Plan to buy good sanding blocks and lots of sand paper. It’s a lot of work to do it right… and yes prep is 95% of the work.
I shot the trunks and engine bay and misc with single stage… and the body with base/clear. I used PPG shop line for my paint.
I found the single stage was harder to spray… easy to lay it on too thick and get runs. The clear also ran on me after 3 coats. You need a variety of guns to paint a car… primer. Highbuild and paint are the basics. I sprayed metallic which comes another set of special problems… getting it to lay down evenly.
I had issues with spraying a sealer coat of primer before painting. The thinned primer was lifting previous coats. Frustrating but I figure it out… after is sanded it all back to metal.
Painting a car takes patience and a lot of labor. It took me several months to do… another reason it costs so much. I visited a lot of local vendors that sell paint. I settled on the one who seemed the most interested in helping me with issues.
I’ve done some spray work before… so I had some skills beforehand. I don’t believe that all paint is the same. Good paint covers well and is predictable. Am pretty sure it’s the first and last car I’ll ever paint… but I did it and learned a lot. I followed a lot of painters on YouTube etc. There is good information out there.
Good luck!
JeffBowlsby
post Aug 18 2024, 12:24 PM
And a great looking car to be proud of as a result.
nivekdodge
post Aug 18 2024, 08:01 PM
This (if it posts) is my mail box painted with rust oleum and a little DuPont clear added. It sprayed ok, but then I painted for 20 years and sold paint for 20 years. The comment about the twelve is correct. Let you know how long it shines
- Lo-Fi Version Time is now: 31st May 2026 - 07:34 AM
