rough running, Car hesitates at 2500-3000 rpm |
pfierb |
Aug 25 2005, 05:14 AM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
Having a hesitation problem with my 73 2.0 ....at a steady 2500-3000 rpm car skips and misses....cleaned and adjusted the throttle switch no help....before I cleaned the switch hesitation started at a steady 2000 rpm...car seems to run worse after cleaning switch....runs great at higher speeds, idles smooth,starts right up.
Any ideas? Paul F. |
mihai914 |
Aug 25 2005, 06:50 AM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Sometimes the switch will be too worn and the only solution is replacement.
There may also be other issues with the car, if you haven't already read through this site which is the reference for our cars. All the info to troubleshoot your problem should be there. As usual, valve adjustment, tune-up and proper fuel pressure is a prerequisite to any D-jet repair. |
drgchapman |
Aug 25 2005, 06:56 AM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
I exact same problem, went through Brad Anders (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) site and diagnosed a TPS problem. Ordered one from Pelican, installed and the little orange 2.0 runs like a champ. The TPS wears out at cruise throttle position, around 3000 rpm. Quite a nice groove in the contacts.
redshift |
Aug 25 2005, 07:38 AM
TPS 99%.
M I have recently found that relays can fail in micro-second bursts, on-off-on-off-on-off. It will make any throttle position other than idle lean, and kill your motor. |
SirAndy |
Aug 25 2005, 11:39 AM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) check the TPS first ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Lo-Fi Version | Time is now: 9th June 2024 - 04:39 PM |
