sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
I had some parts laying around so I got bussy
T-III specs 1776 welded cw 69mm 90.5 w total seals 40 x 35.5 041 heads @ 52cc .044 deck height, CR 8.5 to 1 H grind, Magnum straight cut gears and 1.25 rockers yes, a 30mm Melling can fit in a T-III Attached image(s) ![]() |
sean_v8_914 |
42mm DCNFs w 32mm venturis. I think thtey are too big but that is what I have.
jet coated 1 5/8 merged Attached image(s) ![]() |
sean_v8_914 |
KEP stage 1
pertronics flame thrower in an 009 dizzy Attached image(s) ![]() |
sean_v8_914 |
it is going into my neighbors 1970 yellow squareback
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Well that looks nice...sent you an email with an offer....I need a motor.
sean_v8_914 |
all the parts were used but measured out nice or cleaned up within spec.
Long live teh dingle ball hone Attached image(s) ![]() |
sean_v8_914 |
cool tins over 8 mm studs need safety wire to behave
sean_v8_914 |
I built two type 1 engines last week. teh super sweet T-III has been sold. this other 1776 is available. it lives in my kit car right now
stock crank stock heads 50cc, CR @ 8.4 to 1 stock Mahle rings 90.5 Ps & Cs 100 grind cam 55 amp alternator dog house oil cooler 34mm Dellorto dual carbs. they are over 10 years old but this is the first time they made it on an engine. I took them apart to inspect prior to install and they are very clean inside Attached image(s) ![]() |
sean_v8_914 |
new type 3 universal case, standard size mains
sean_v8_914 |
baby Dells, new linkage, old K&N air cleaners
sean_v8_914 |
before
sean_v8_914 |
after
sean_v8_914 |
I like the lines of the rear fenders
sean_v8_914 |
rear side marker is 68 Barracuda
009 dizzy with points Attached image(s) ![]() |
sean_v8_914 |
every guy likes some head...s
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
kelmark? always loved em'. what year pan did you use?
k |
sean_v8_914 |
ball joint front & IRS. I dont know what year it is. reg is 78 but pan is earlier. i think 70
sean_v8_914 |
exhaust is ugly but does its job
Lo-Fi Version | Time is now: 7th July 2025 - 08:08 AM |
