Full Version: type 1 & T-III engine builds
sean_v8_914
I had some parts laying around so I got bussy
T-III specs
1776 welded cw 69mm
90.5 w total seals
40 x 35.5 041 heads @ 52cc
.044 deck height, CR 8.5 to 1
H grind, Magnum straight cut gears and 1.25 rockers
yes, a 30mm Melling can fit in a T-III
sean_v8_914
42mm DCNFs w 32mm venturis. I think thtey are too big but that is what I have.
jet coated 1 5/8 merged
sean_v8_914
KEP stage 1
pertronics flame thrower in an 009 dizzy
sean_v8_914
it is going into my neighbors 1970 yellow squareback
Joe Bob
Well that looks nice...sent you an email with an offer....I need a motor.
sean_v8_914
all the parts were used but measured out nice or cleaned up within spec.
Long live teh dingle ball hone
sean_v8_914
cool tins over 8 mm studs need safety wire to behave
sean_v8_914
I built two type 1 engines last week. teh super sweet T-III has been sold. this other 1776 is available. it lives in my kit car right now
stock crank
stock heads 50cc, CR @ 8.4 to 1
stock Mahle rings 90.5 Ps & Cs
100 grind cam
55 amp alternator
dog house oil cooler
34mm Dellorto dual carbs. they are over 10 years old but this is the first time they made it on an engine. I took them apart to inspect prior to install and they are very clean inside
sean_v8_914
new type 3 universal case, standard size mains
sean_v8_914
baby Dells, new linkage, old K&N air cleaners
sean_v8_914
before
sean_v8_914
after
sean_v8_914
I like the lines of the rear fenders
sean_v8_914
rear side marker is 68 Barracuda
009 dizzy with points
sean_v8_914
every guy likes some head...s
rhodyguy
kelmark? always loved em'. what year pan did you use?
k
sean_v8_914
ball joint front & IRS. I dont know what year it is. reg is 78 but pan is earlier. i think 70
sean_v8_914
exhaust is ugly but does its job
