Steve1956 |
Newbie ![]() Group: Members Posts: 27 Joined: 4-November 22 From: Morocco,Indiana Member No.: 26,966 Region Association: None ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,523 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I looked at this when I went to the Cayman 6 speed. You can't remove the ends. They are crimped onto the cable. I used Numeric shift cables. https://numericracing.com/products/performa...-cables-986-987 They are not cheap, but they use really nice joints on the ends of the cables, and they are removable. |
ClayPerrine |
Another thing... on my car, I ran them through the speedo cable and shift rod openings on the firewall. But to do it, I had to turn the flanges down on the shifter end of the cables.
That involved fitting a long piece of pipe to the back of the lathe to support the cables, and spinning the lathe VERY slowly while removing the flange. Then once they were through and in the car, I just put another nut on the cable to anchor it to the shifter. |
Steve1956 |
What I thought I would try if the rod is soft enough,cut the end off and thread it with a die. They are 6mm in diameter.
Whoa!,,,I guess they are pricey! Yeah,gonna try threading them! |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,268 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
+1 on the Numeric cables. Shifts like silk.
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,497 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Another thing... on my car, I ran them through the speedo cable and shift rod openings on the firewall. But to do it, I had to turn the flanges down on the shifter end of the cables. That involved fitting a long piece of pipe to the back of the lathe to support the cables, and spinning the lathe VERY slowly while removing the flange. Then once they were through and in the car, I just put another nut on the cable to anchor it to the shifter. Da man. You can visualize skill in getting the spin just right. |
Lo-Fi Version | Time is now: 26th September 2025 - 06:04 AM |
