> Double VDO Gauge Pod (Ashtray Mounted, 3d Printed), Includes Files
RTz
post Feb 8 2025, 02:54 PM
I put this together for one of our 914World members. It slides into the ashtray rails, no fasteners or drilling holes required.
STL: https://www.dropbox.com/scl/fi/2wnqiw1y1to6...75hgoj&dl=0
DWG: https://www.dropbox.com/scl/fi/xlfj9la982y7...jl26rm&dl=0
Disclaimer:
1) Designed for 52mm VDO gauges only. The two gauges shown have different depths, though either gauge will work on either side, I have no knowledge if VDO has built gauges with different depths or stud spacing other than these two. The voltmeter is the deeper gauge and has a body depth of 34mm.
2) Pictured on a '72 model. I assume ashtray's & rails are the same for all years but I don't know that with certainty.
Do your own diligence.
Peace, Ron
Replies(1 - 12)
slowrodent
post Feb 8 2025, 03:24 PM
Yeah....I'd pay for one of these. Very nicely done. (IMG:style_emoticons/default/beer.gif)
emerygt350
post Feb 8 2025, 04:25 PM
Let me know if it shrinks. What filament did you use?
bkrantz
post Feb 8 2025, 09:18 PM
Very nice. If you are open to suggestions, the next version could have the gauge openings tilted towards the driver. I once made a sheet metal mount like that, and just a small angle made the gauges much easier to read.
fixer34
post Feb 13 2025, 06:16 PM
So I was the member that worked with RTz (Ron) on this. I received the prototype today. A LOT more complex than I had thought, but it does check all the boxes:
Easy install (in place of the ash tray) with no modifications.
Access to the back of the gauges when pulled out for lights/wiring
Fits standard VDO gauges
Pretty close match to dash
I tried to get some detail pictures of the design, not sure if tilting the gauges would be an option if retaining the threaded studs. Have to mount mine in the car to be sure, but I don't think viewing will be an issue.
fixer34
post Feb 13 2025, 06:19 PM
more pictures
back Attached Image
side Attached Image
bottom viewAttached Image
Montreal914
post Feb 13 2025, 09:34 PM
QUOTE(RTz @ Feb 8 2025, 12:54 PM) *
Nice part. I like the Gaudi inspired support material. (IMG:style_emoticons/default/biggrin.gif)
BTW, cool tach. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/sunglasses.gif)
infraredcalvin
post Feb 13 2025, 10:06 PM
Distracted Member
Very cool, I’d buy one too…
+1 on the angled gauges… i did a radio plate with angled (pvc) gauges… two different depths cause one of my gauges had a thicker bezel than the vdo gauge…
fixer34
post Feb 14 2025, 12:01 PM
QUOTE(infraredcalvin @ Feb 13 2025, 10:06 PM) *
I think the challenge with doing angled gauges would be it is a much tighter space, plus the right side would need to be a smaller depth.
Lastly, they would be offset in the opening; the left gauge tight against the left side, the right one more to center with a wide space on the right side.
The only 'glitch' I found so far is apparently the early dash ('70) is a little narrower around the opening on the bottom.
RTz
post Mar 22 2025, 06:05 AM
"New & Improved" version and for sale:
http://www.914world.com/bbs2/index.php?showtopic=373861
SKL1
post Mar 23 2025, 08:47 PM
PM sent.
RTz
post Mar 25 2025, 11:31 AM
Got it, and replied.
Thank you!
RTz
post Apr 5 2025, 08:39 AM
- Lo-Fi Version Time is now: 16th November 2026 - 01:16 AM
