About racing a 914 with a swap..., What class? Does the PCA care? |
Matt Monson |
Aug 29 2005, 09:07 AM
Member Group: Members Posts: 156 Joined: 9-August 05 From: Boulder, CO Member No.: 4,562 Region Association: Rocky Mountains |
As some of you know, I am going back and forth on putting in a 2.4l six or swapping a Subaru Ej25. I want to know what impact the Subaru engine will have on racing the car. I am specifically wondering how the PCA (and RMR since I am in Colorado) treats 914's with non-Porsche engine swaps in them. I want to be able to run my car at club events. I know there won't be a problem in SCCA racing. But I don't know about the "official" Porsche clubs...
Cap'n Krusty |
Aug 29 2005, 09:09 AM
The "national" PCA line is Porsche/Porsche. Your region MAY vary, but probably not in track events, and certainly not in points toward any sort of trophy. The Cap'n
type47 |
Aug 29 2005, 09:13 AM
i believe the policy is that you will not be allowed to race in pca club races unless your car has a porsche motor. if you put a -6 in your car, you will be put in a racing class designated for the improvements you made to your car. your improvements could very well put you in a class of very serious ($$$$$$$$$$$$$$$$$$$$$$$$$$$$$$) racers and you may not be competitive, if that makes any difference to you. stock 2.0L 914's race in class J if i remember correctly. i have a car (but i don't race (yet)) that is a 2.0 w/webers and 911 suspension that is class I. you could probably get onto the pca website and find racing rules w/classes and modifications spelled out.
Joe Bob |
Aug 29 2005, 09:14 AM
In most cases you will be in exhibition "X" class. Depending on the region they will allow you to compete...some don't allow them at all.
Converting to another Porsche engine is cool....juts njot chebbie, scoobies or other non Porsche engines....after all...it IS the Porsche Club. |
DanT |
Aug 29 2005, 09:28 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
In Zone 7 GGR (San Jose ca area) you may only run Porsche Chassis, motor and trans to compete in our TT series. Anyone can AX with most any type of car, in fun category. No awards or trophies at the end of the season.
Basically it must be a Porsche in all respects mechanically to be allowed to run in Timetrials. I have only seen one exception to this when someone years ago wanted to TT their POOPER and was allowed a one time only exemption. I believe this is the case in the Regions (zones) that have TT events. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
brant |
Aug 29 2005, 09:35 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Matt,
yep all of the above is true. I race in PCA club racing, RMVR vintage racing, and RMR drivers ed. for colorado you will not be allowed to run in any of those clubs with a subaru engine. You will be allowed to do drivers ed events with a couple of the multi-car type clubs that have much looser "run whatya brung" rules. Their events are not racing and not wheel to wheel. I don't think they use ambulance support either if that factors in for you. I'm not as familiar with the SCCA classes, but my guess is that you'll be screwed with the subaru engine there also. They will probably put you into a full modified class. Although I don't know that for sure. RMR says motor and tranny from porsche in a porsche chassis. regarding the -6, yes you will be in modified classes based upon displacement, but you would still be allowed to run in both RMR-DE and PCA club racing. brant |
Matt Monson |
Aug 29 2005, 09:48 AM
Thanks folks. This is really good information. I don't really care about being competitive. I just want to come out and participate. So if my car was banned all together, that would really bite.
In light of the above, this decision just got really difficult. I have had a low mileage Ej25 with ECU and wiring harness just dropped into my lap as payment for doing a WRX swap on a guy's MY00 2.5RS. And I found out from Renegade that their Subaru conversion kit doesn't require any welding to install. This is important to me, because I would always want to be able to cleanly revert my car to original spec to maintain some sort of value. |
Mueller |
Aug 29 2005, 09:56 AM
welding = no cutting original sheetmetal = yes the renegade kit requires the radiator up front, which also means cutting...sure it can be repaired later on, but not too easily...AFAIK, there are no "kits" to adapt the motor and radiator into the engine compartment. |
Matt Monson |
Aug 29 2005, 10:01 AM
I know their kit has you cutting sheet metal. I think I have figured out a solution around that. It will require cutting up a hood, but I have a yard full of spare hoods at my disposal...
jasons |
Aug 29 2005, 10:33 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
So whats considered a Porsche motor in a 914? Specifically, if I build something out of a VW Bus case, its not really a "Porsche" motor".
brant |
Aug 29 2005, 11:01 AM
I guess it would depend if they decided to check the # stamped onto the engine case...
not too likely they would care about a VW bus motor... more likely they would care about a Type 1 much more likely they would care if they found a subaru or Chevy motor in there.... brant |
nocones |
Aug 29 2005, 01:49 PM
Sportscar lunatic Group: Members Posts: 428 Joined: 17-June 04 From: Santa Rosa, CA Member No.: 2,220 |
That's why I'm going to make some special valve covers that say "Porsche" on them! (IMG:http://www.914world.com/bbs2/html/emoticons/finger.gif)
skline |
Aug 29 2005, 01:52 PM
Well Fuch em then, I dont own a Porsche anymore, it's a Chevrolet 914 (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Brando |
Aug 29 2005, 01:57 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
What class would the guy with a 928 4.5L be in, then? GT-only or X?
Kostamojen |
Aug 29 2005, 06:06 PM
Newbie Group: Members Posts: 37 Joined: 30-July 05 From: Roseville, CA Member No.: 4,504 |
Of course, the Subaru clubs would welcome you with open arms (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
flesburg |
Aug 29 2005, 08:14 PM
Senior Member Group: Members Posts: 506 Joined: 22-November 04 From: Pontiac, IL Member No.: 3,162 |
If you want to "race" in AX or Club racing, PCA will allow all kinds of mods including swaps to "other" types of Porsche engines, but will not allow non Pcar's in Club Racing, nor non Pcar engines.
But if you are willing to do DE's and are willing to stay with them, (thats what we do), all of the Ohio regions, Chicago, St Louis, Kansas City, will allow other makes of cars and we have probably done over 100 events in 18 years. Some east coast regions with huge memberships restrict their events to Porsche only, but even they allow us to run with them (we have a 3.2 L in our 914). We have done DE's with PCA/BMW/AudiQuatro among others clubs, and they all allow Cobra kit cars, Ferraris, Alfas, Corvettes, Vipers, Subaru's, Mazda, Chevy powered 914s and even Mustangs to run with us and I have never heard of anyone being refused because of the make of the engine. (and they all seem to accept anything that will pass a safety inspection). |
brant |
Aug 29 2005, 10:29 PM
Dale, in colorado though that doesn't hold true. maybe subaru club, or nissan club, or some other club would allow Matt to participate, but porsche club will not. sorry but we have some drivers ed events that cap at 100+ cars and they don't need to let any other cars in. so not true where Matt lives unfortunately. brant |
grantsfo |
Aug 29 2005, 11:40 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Yeah Porsche club is pretty snootie about Porsche power plants. But think of the options there. Cayenne V8 or maybe even the new Cayenne V6.
Matt Monson |
Aug 30 2005, 11:13 AM
Yep, Ultimately, my decision may have been made for me. Since I work in the industry, and the company pays my PCA and RMR dues, it is important that I be able to be a part of these local events. There is just too much collateral advertising for the shop by having me be out there. Ultimately, this would be a non-issue if I could afford another Porsche as a dedicated track car. Maybe in a year or two... |
Ferg |
Aug 30 2005, 11:22 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Just pull the motor out the the boss's racecar when he's not looking (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) . I'm sure he wouldn't mind. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Ferg |
Lo-Fi Version | Time is now: 1st June 2024 - 08:42 AM |
