fuel injector boots, on fi leads |
rhodyguy |
Aug 29 2005, 12:52 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
bad # in my old aa catalog. don't see them listed at the bird. any sources? also, what's the trick for getting them over the plug ends? started squirting down fasteners on the new 2.0 with pb blaster this am.
k |
zymurgist |
Aug 29 2005, 01:31 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Hmmm. I was thinking of using the liquid electrical tape and just painting that over the connector. Used that on a few original connectors on my Corvette and it seems to stick fairly well.
SLITS |
Aug 29 2005, 01:34 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Somebody was talking a long time ago about making them or being able to source them. Maybe it was Jeff Bowlsby.
You would have to take the connector off with the special tool that Bowlsby says it takes. |
rhodyguy |
Aug 29 2005, 01:36 PM
usually not my m.o. being so "proper". i want to be a little picky this time. prefer the correct boots. i REALLY don't want to call (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) aa to see if they still stock them.
k |
MarkV |
Aug 29 2005, 01:42 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
They haven't been available from Porsche for a long time. I bought some from AA 10 years ago and they came from Mercedes Benz.
rhodyguy |
Aug 29 2005, 02:11 PM
looks like jeff bolwsby has them for his new harnesses. i emailed him.
k |
Dave_Darling |
Aug 29 2005, 02:25 PM
The boots that Jeff uses are not the same as the originals. They are better, in some ways, but they are not original. The M-B boots are as close as you'll probably get, unless you can sweet-talk Jeff into selling some of the old boots off of the core harnesses he gets in.
The M-B ones are all black, too, so no grey ones for the two forward injectors either. I may be able to dig up the part number; I used to have it stored away somewhere.... To install the boot, take the pins out of the plug body using a pin extractor tool (or a very stiff small piece of metal). Slide the boot over the bare pins and wires, then plug the pins back into the plastic plug body. --DD |
rhodyguy |
Aug 29 2005, 02:31 PM
thanks dave. i'm not as concerned about correct as i am proper. new properly uncracked ones that will function. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
k |
eric914 |
Aug 29 2005, 04:28 PM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
At one point I jotted down the following in my handy info book. I'm not shure where the info came from of if they will work as I have not tried them.
Volvo PN 943693 Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 05:22 AM |
