> Electric Windsheild washer conversion?, Is there an electric washer conversion available?
Mr.Vman
post May 15 2025, 06:02 PM
1976 914, replacing upper steering column bearing. Noticed the wiper switch has the spare tire powered windsheild washer system. Is there a conversion to replace the spare tire powered washer to electric, using the wiper lever? I know there are push button replacements. What about a lever controled washer? Hopefully a current available conversion kit. Thanks in advance, Steve
Replies(1 - 10)
Ishley
post May 15 2025, 06:13 PM
The short answer is yes. I did it on my 72. You may have to replace your washer switch/stalk in your steering Column with a 924 version.. run some wiring… buy a small pump and connect it all together. There are various posts about how to do it in this forum. Mine works good.
Thunderchief
post May 15 2025, 07:05 PM
Auto Atlanta makes a kit. I put one on and it works great.
jim_hoyland
post May 15 2025, 07:06 PM
Get that VIN ?
See: https://www.pelicanparts.com/techarticles/9...tric_washer.htm
friethmiller
post May 15 2025, 07:24 PM
I did this kit. It was very good quality and it uses your existing stalk/lever. I just bought the switch since I already had a pump so this upgrade was dirt cheap for me. The switch mounts so when you pull back to get fluid the button is pushed and activates the pump. Wiring this in with a relay was really simple. Just make sure you have a breather hole in the cap of the washer reservoir so fluid can move. I believe there's already a hole there from a hose. Just make sure it's open/not clogged.
https://carmagic.us/washer.html
FlacaProductions
post May 16 2025, 08:27 AM
I did the Carmagic version and think it's the way to go. Works great but honestly, - I never use it!
friethmiller
post May 17 2025, 08:10 PM
QUOTE(FlacaProductions @ May 16 2025, 09:27 AM) *
If I'm running the wiper pump, I might as well wash the whole car again (IMG:style_emoticons/default/biggrin.gif)
post May 17 2025, 09:43 PM
Resident German
I did a DIY write-up many moons ago:
http://www.914world.com/specs/tech_el_washer.php
post May 18 2025, 08:59 AM
Yep. I used Andy's write 10+ years back.
FlacaProductions
post May 18 2025, 09:35 AM
Same. Thanks, Andy!
StratPlayer
post May 18 2025, 10:20 AM
StratPlayer
ditto
- Lo-Fi Version Time is now: 3rd June 2025 - 02:56 PM
