| jmargush |
May 20 2025, 11:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 512 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
Curious as to what you all might be doing for gearing on the autox course.
I have a 2056 with what I imagine is a stock gearbox. We autox at the Tire Rack so the course is not exceptionally big or long , but I find myself needing 3rd gear but it usually isn't enough time to warrant makin g the shift due to needing to go back down to 2nd. However it feels like I would be running at the redline in 2nd for too long as well. Is it common to experience this? Is there a longer second gear available? |
| 914werke |
May 20 2025, 11:29 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,762 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Pretty common scenario. Challenge is 2nd gear is fixed in the 901 so the remedy is an expensive one, replace the main shaft with one from the 904 with a replaceable gear so you can change your ratio.
| jmargush |
May 20 2025, 01:18 PM
Pretty common scenario. Challenge is 2nd gear is fixed in the 901 so the remedy is an expensive one, replace the main shaft with one from the 904 with a replaceable gear so you can change your ratio. Thanks, that makes it a fairly easy decision, not looking to spend extra money! |
| PlaysWithCars |
May 26 2025, 04:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 544 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest
Yep, standard practice for a 914. You can put in a lower third gear so you're into the power curve better when you shift and able to use third through some of the slower events that you would need to downshift to second if you had a stock third gear.
| sixnotfour |
May 26 2025, 05:52 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,378 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| Shivers |
May 27 2025, 07:06 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,640 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Hi. I got my car at 24 and didn't know anything about gear stacks let alone have the money to do a swap. But I lived between two canyon roads so I went from a 65 series tire to a 50 series and my gearing was wonderful. Just shortened them up. Just a thought.
@jmargush |
| yeahmag |
May 27 2025, 09:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,485 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
I have a stock 1st and 2nd then M, S, Z for my autocross car. MANY courses with a 2056 won't be big enough for a 2-3 shift. I've actually designed this motor and the forthcoming one to go to almost 8K RPM and not explode to avoid the 2-3-2 shift on medium sized courses.
The next motor will be a high strung 2270cc which will likely use 3rd more often than what I do now... |
| GregAmy |
May 28 2025, 06:42 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,701 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
A-HB-N-U-ZA, 4.83 final drive, 205/50-15 200TW Contis.
Warmed-over 2L 4-banger and shorter tracks like Lime Rock, Thompson, and Palmer. 1st gets me off the grid then it makes for a nice usable H-pattern 4-speed. Usually 115-ish mph at the end of these longest straights so around 5800 RPM or so. No idea how this would work at longer tracks like VIR and Watkins Glen but I bet the post-T2 Uphill at WGI would slow me down enough where it wouldn't be a problem into the Bus Stop (I'll run the engine up to 6300 or so). So you're going to ask about that HB 2nd gear. No, I didn't buy the 904 shaft. Instead, I know someone who has the skills and talent to actually machine off the "F" gear to the OD of the splines and manually machine and file in the splines to use any 901 gear. It was a wonder to behold, watching it being done. And it works great (we should pull apart that transaxle this winter to inspect it). I'm not going to mention the name here because this was done as a favor, and by the time it was all done on a retail level it probably would have cost as much as just buying a 904 shaft (reprods appearing to go for $1500). Plus, I'm not sure he'd want to do another one (if he does, then he'll let me know...) But I can offer that tossing down that $1,500 really opens your opportunities. And, The Fates willing, it's a one-time purchase. - GA |
Lo-Fi Version | Time is now: 4th October 2026 - 10:55 PM |
