Tobra |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 ![]() |
How is it supposed to be secured? I am thinking bolt with washer, through valence and body of car/rear bumper, then washer and nut. What size bolt, metric 10 mm maybe. Should nuts, bolts and washers be stainless or anything to prevent rust?
914GT |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region ![]() |
I just installed one this afternoon. I basically did what you described and found some stainless steel screws. On the ends I used longer screws and some rubber washers similar to what was used originally.
Tobra |
so rubber washer to protect sheet metal and bumper, makes sense, sort of like the fender welt on a bug where the fenders connect
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
self-tapping screw, hex-head 4,8mm x 16 (914.6 - 19)
washer, 5,3mm speed nut the ends are different. for 72+: hex bolt M5x20 inserted from top washer, 5,3mm spacer (lots of cars are missing these...) lock ring (split lockwasher) hex nut, M5 70-71: self-tapping screw, hex head 4,8mm x 19 spacer washer 5,3mm speed nut Attached image(s) ![]() |
Tobra |
I have been looking for these fasteners for a few weeks. The ones for the ends are readily available at hardware store, metric self tappers are nowhere to be found, any suggestions on a source, dealer perhaps?
ArtechnikA |
since it's only going into a speed nut, unless you're looking at a national-class concours competition, the US-sized hardware should be just fine.
interestingly, 4,8mm is a gnat's eyelash from 3/16" ... |
Tobra |
dude, you rock
now I don't have to drive with my ass hangin' out (IMG:http://www.914world.com/bbs2/html/emoticons/rocking nana.gif) where did you get that picture anyway |
ArtechnikA |
the picture is from ETKA - popularly known as "PET." available on CD through dealer sources now, for not much, and elsewhere. i'd go for a legit copy now that they're available... look around for "PET CD" and you'll find links... it has all the parts information for *all* the Porsche models. an invaluable resource even if you don't have to deal with a 356 Pre-A, a 914.6, and a '71 911 with '75 engine and '84 transaxle... as for the time - something of a sore subject. lots of stuff i need to be doing today, but you caught me finishing breakfast so it's an easy reply. my day job has me in front of a computer 8-10 hrs a day, so i can usually take a moment to help out. but there is much to do this weekend, many overdue projects i have to make progress on ... |
Lo-Fi Version | Time is now: 4th July 2025 - 03:34 PM |
