| TRP |
Oct 17 2025, 11:19 AM
Member ![]() ![]() Group: Members Posts: 416 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Hello 914 Hivemind!
I have purchased everything I need to add/wire up a combo gage for my 75 1.8. I am going to run the wires this weekend. I found the wires in / on the center tunnel for the console gauges, running the wire from the green / black wire from the console to the gauge is straight forward. Where in the engine compartment do I connect the wire from the motor/sending unit to the 'other end' of the wire in the center console? I read that the harness is somewhere over by the battery tray/computer. I haven't dug into it too deeply yet, but I was wondering if I should be looking for a big terminal plug or if it's just a single clear (yellowed) wire joint plug like what I'm seeing in the console? Thank you! Ted |
| wonkipop |
Oct 17 2025, 01:06 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,627 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
Lo-Fi Version | Time is now: 26th July 2026 - 01:31 AM |
