need engine stand, what's good? |
goose2 |
Sep 7 2005, 01:09 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
I need to get an engine stand suitable for a six. Are the HF el-cheapo's any good? Do I really need the special Porsche/VW mounting accessory or does the 4 bolt adjustable rig do the job (I'm not splitting the case). Anybody got one for sale?
Thanks |
ArtechnikA |
Sep 7 2005, 01:20 PM
yes. yes - or the Mainely Custom By Design adapter ring no - unless you get the adapter ring. $40 at Harbor Freight for a 750 lb stand. i'm going to go get another one tonight. the 1000-lb version is on sale for $50 - but you won't need it... i have the 2,7 fastened to a real P201 mounted to such a HF stand. now that i need to tear down the Subie engine too, i need another stand... 10mm 911 CV bolts work good for mounting the engine to the P201 or adapter. |
jd74914 |
Sep 7 2005, 02:30 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
where would you find that adapter ring? |
ArtechnikA |
Sep 7 2005, 02:39 PM
'tis a trick question, yes? MainelyCustomByDesign.com Mainely Custom By Design-dot-com adapter ring web page |
yeahmag |
Sep 7 2005, 03:26 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
The "standard" VW stands only attach to the two studs at the bottom of the case. Why couldn't you use only two (or maybe three) of the arms on the "HF El Cheapo" stand...???
That was my plan as I just picked up the 1000lb one for $39.00. -Aaron |
ArtechnikA |
Sep 7 2005, 03:34 PM
first, no, they don't. they capture one bottom stud and one top mounting bolt. if it captured both lower studs, you could never split the case. second, the proper (P201) tool secures the entire side of the case in a machined flange, and provides uniform support for the entire case, not concentrated at only the two places where the bolts attach. the cheap engine brackets are designed for T-I VW's. they're scary with T-IV's and (IMO) downright dangerous for a fully dressed /6. you do *not* want a magnesium-case 911 engine falling three feet onto a concrete floor. the currently available P201's have 5 arms, which is enough for a full twin-turbo engine. they started (in Olden Tymes) with 2 arms but sprouted more through the years as engines got heavier. any of the 3- or 4-armed versions should be adequate for a NA engine through an SC. mine has 4 arms and is holding my 2,7 perfectly securely. |
goose2 |
Sep 12 2005, 03:18 PM
I bought the HF 1000# stand for 40 bucks and ordered the Mainely Custom mount adaptor for 165. Thanks for the advice Rich (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
ArtechnikA |
Sep 12 2005, 03:28 PM
you are welcome. i went for a 750-lb stand this weekend for the Subie but they were out and i also wound up with the 1000-lb stand (for the same $40 as the 750-lb they didn't have...) |
Joe Bob |
Sep 12 2005, 03:32 PM
Pelican had the ring for $325 at the GAF....wtf, I said....saying it again.... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
goose2 |
Sep 12 2005, 03:46 PM
probably a different animal...Mainley's looks like this:Mainely adaptor |
Joe Bob |
Sep 12 2005, 03:50 PM
Noooopppersz....same thing. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
sixnotfour |
Sep 12 2005, 03:55 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Instant Gratification purchase $325 @GAF I bought 8- P201 and clamps for 75.00 at auction 3 years ago Paul Weir Bankcruptcy (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) |
yeahmag |
Sep 12 2005, 04:21 PM
I'm emberassed to even say this, but I found that JC Whitney sells an adapter for standard engine stands. It's basically the cheap, 2 arm stand that they sell built for a standard engind stand. JC Whitney Part Number ZX128021U. The picture is incorrect on the web site, but I spent some time on the phone with their tech support to better my odds of it working for me.
I've ordered it and will let everyone know if it fits and how well it works. I know there is some concern about strength/weight, but every VW guy I know has a 2 arm stand and has for years... No problems. I understand I'd be a fool to put a 6 on there due to the increased weight, but I figure the day I can afford anything out of Germany with 6 cylinders I'll be able to afford better tools too... If that part fails to fit the bill I'll buy the adapter ring from Pelican/Mainley. -Aaron |
Lo-Fi Version | Time is now: 1st June 2024 - 03:15 PM |
