Gauge Problem |
Gauge Problem |
drew365 |
Aug 2 2003, 09:04 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
I built a tri gauge about a year ago. Last week the pressure gauge started going all the way to the top when I turn power on. At first I thought it lost it's ground but the ground seems to be fine. Plus the temp and gas gauge use the same ground and they work fine. Anyone have a suggestion. The lead to the sender seems to be okay at both ends. Here's a pic of the gauge.
Attached image(s) |
J P Stein |
Aug 2 2003, 09:44 PM
You have power & ground or the needle wouldn't move....WAG....the sensor.
drew365 |
Aug 3 2003, 09:51 PM
I disconnected the sender and the gauge still goes all the way up when the key is turned on, so I'm sure it's not the sender. I can't find any bad wiring so I took the gauge out and will take it to N. Hollywood Speedometer in the morning. I should have gotten a new gauge in the first place instead of using a used one when I built the tri-gauge. It's a real PITA disassembling the gauge. I hope it's the last time.
Dave_Darling |
Aug 3 2003, 10:09 PM
The wire from the sender to the gauge has shorted to ground somewhere.
--DD |
drew365 |
Aug 4 2003, 06:45 AM
Dave; I disconnected the sender at the gauge, so it can't be the wire to the sender.
drew365 |
Aug 5 2003, 09:16 PM
QUOTE The wire from the sender to the gauge has shorted to ground somewhere. I'm an idiot. Dave Darling, you da man! Rather than take your advise and check my sender wire which is only a year old, I took the gauge out twice, put in a new pressure module and sender. At that time there was nothing left to change except the sender wire, I found it was rubbing on the steering column. Fixed that and tied it off to the side and now the pressure gauge works. Live and learn, I hope. |
Lo-Fi Version | Time is now: 6th June 2024 - 06:26 AM |
