bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
okay, my heating system is marginal at best...i still freeze when driving and full heat.
i have seen some examples of ceramic heaters offered online from various retailers, so question is how well do they work? |
tanner |
Member ![]() ![]() Group: Members Posts: 133 Joined: 17-April 04 From: Findlay Ohio Member No.: 1,942 ![]() |
I have one in my 911, and it works pretty good unless it's below 40 degrees. The one I have is called Back Seat Heat. I have seen them at NAPA for around $50.00 or so.
bd1308 |
do you have the cigarette lighter one....I was going to look at getting the high-amp version taht would be hard-wired to the power.
scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
britt, dont waste you money on an electric heater, you would need at least 700 watts ( on 30 degree days )to really make a difference. which works out between 50 and 60 amps ( 12 to 13 volts ) or about as much as your alt puts out. the best thing you can do is to get some in seat heaters, then you will be warmer with out trying to heat the whole car.
or get some new HE's |
bd1308 |
the jag and the rover both have heated seats, but they never work....both keep blowing fuses.
crazy english types. how hot can these things make the person sitting on them? |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
seat heaters will make you feel all warm and fuzzy... like when you pee in your pants (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
check with Craig from Camp914, he has the seatheaters listed on the resources forum |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
fine tune your marginal heating system. it should blow HOT air.
k |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
I've got one from Harbor Freight (oooh, how long will it last?) that plugs into the lighter. My heat works great, though. I've got it for emergency windshield defrosting in case I gotta get a clear WS some February morning before the engine heats up. I've actually never plugged it in....
I've never had insufficient heat, I made sure the various connections 'tween HEs and J-tubes and impeller housing were nice and tight by bending and reshapping the bent up little screwed on "compression plates" that hold the parts together. Recently I put SS on heat exchangers and now it doesn't even smell! |
bd1308 |
well my 2.0 leaked so much oil I just ended up drinking oil after awhile....
I'll have to see what I can do with this motor....but right now it's running too hot and therefore leaking oil and such. I think I can end up with a leak free car. The last "straw" was the breaking of my heater pull cables...can't get much heat without the pull cable.... and the first cable on the 3 way selector for air comfort needs to be looked at....I need to get into the fresh air box and clear out the garbage that is siezing the flap inside blah blah.... but I see the light at the end of the tunnel...I just didn't know what to expect with all of the heating options.. |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
This one does a pretty good job at temps in the 20's you wont cook but your cabin will be warm. It needs to be hardwired to the battery. I mounted it to a spare ashtray.
Attached image(s) ![]() |
rhodyguy |
so, spend money on a fan/aux heater, etc, for tepid heat. or buy a new control wire from the bird and be done with it. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
k |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Britt, I'd have to agree with Kevin. Man, my heater will roast me out in no time. I know your climate gets colder than mine, but still, it should put out plenty. The system is simple. Are you sure yours isn't just in need of some attention? Or do you think it's working perfectly and still doesn't put out enough heat?
You could always install one of those gasoline heaters... THESE THINGS put out more heat than a 12v electric. |
rhodyguy |
wow. diesel or kerosene too. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) . to heat the car!! WOW!!. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
k |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,294 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
The only heating solution for a 914 is stainless steel heater boxes and a properly functioning stock heater system. You are certifiably nuts to think about electric heat.
BTW, I know the SSI boxes work well from years of winter experience in Canada. |
bd1308 |
i have the SSI exhangers....
flapper valves look fine. spongy NASA hoses look fine...i forgot where i put them though. |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Don't know the prices for one of these, but a Espar B1LC heater is only 14x5x5.5 inches, I think that could fit somewhere in a 914 engine compartment, under the back trunk, or in the front trunk. Would 7500 BTU be enough to heat the 914 interior? With the prices of original Heat exchangers @$2200/side, and marginal heat/fit of aftermarket 914-6 units, a set of headers and one of these heaters may be the way to go on a conversion. Anyone done one yet?
Rand |
There's something wrong with your heating system, and it shouldn't be complicated or expensive to fix. Start breaking it down. Does your blower work? If you take a hose loose at the driver's side footwell - front/top of long, it should be blowing a pretty good amount of hot air there. If it does then the problem is at least narrowed down to the dash area, vents, controls... and you'll have temporary heat in the cabin. If not, then you know it's at the back... HE connections, ducts, flappers, blower... Does the airflow change there when you move the heater flap lever?
bd1308 |
well i took it all off when i did the engine swap, then plugged the ports when i leaked a ton of oil....
i'll have to put it back together...i'll do it during fall break sometime. i think it would be really cool If I could make the fall foliage or something.. |
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California ![]() |
The stock heating in my car seems to work fine too... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Although in winter it doesn't get THAT cold here in Cali.. Since the hot air just dribbles out, it does take the cab 5-10 minutes to actually feel warm, but once it's warm, you notice it. (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif)
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
That's not a resistance heater in the middle of the dash,
That sucka's a mini-microwave..... Always have hot coffee and donuts with one of those, (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Extra heat if you leave the door open while it's running..... (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) Ken |
Lo-Fi Version | Time is now: 16th July 2025 - 04:29 PM |
