olav |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None ![]() |
My intermediate plate on my 901 tranny is seeping tranny fluid. How does one go about stopping the leak? Are there a couple of gaskets to use or some sort of liquid gasket. Also, when I take off the rear tranny cover to fix this thing are there any suprises that come springing out that I should be aware of? I'm thinking I can slid the intermediate plate off and apply the sealant and slide and re-assemble the whole thing again without too many issues. Also, are there specific torque values when re-assembling? Thanks. |
jr91472 |
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 ![]() |
On what side of the intermediate plate is it leaking? On the end cover side (toward the back) or the gear stack side (toward the motor).
If it is just the end cap side, fairly easy to do. Just pull the end cap off (I forget how many 13mm nuts) and lay on a new paper gasket. I have never used any type of sealent, but others may dissagree. You will need to clean both surfaces thoroughly to get a flat and smooth mating surface. Check out Bondo's thread in the classics for photo's If it is the gear stack side.....a little more complicated. JR |
Red-Beard |
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None ![]() ![]() |
If the tranny is in the car, when you pull the cover off, reverse will drop on the floor.
The best way to re-install reverse is to use grease as a temp glue to hold all of the pieces in place, including the washer which sits on the intermediate plate. The manuals, etc do not suggest using sealant. I was told early on that greasing the intermediate plate before installing the paper gaskets would help. I now use a non-hardening gasket sealant and I do not get leaks. If the gasket is between the outer cover and the intermediate plate, there is only 1 gasket. Just install. If the gasket is between the case and the intermediate plate, it is actually a shim. The shims are color coded. Make sure you replace the correct one(s). Sometimes more than 1 gasket is used!!! James |
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
James, while on the subject of tranny leaks..........I have a persistant leak from the small plate on the bottom rear of the tailshifter in my six. Replaced the gasket last week and it still leaks. The plate seems to have a flat sealing surface. Any tricks/suggestions?
914GT |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region ![]() |
I'd suggest just retorqueing all the bolts/studs first and see if that takes care of the leaks. If it doesn't then pull it apart. Try the easy things first.
olav |
Ok thanks. 1) I'll re-torque, 2) Replace easy one first if still leaking. 3) Let hard one leak till I get some balls. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Stephane |
Newbie ![]() Group: Members Posts: 45 Joined: 13-February 04 From: New Brunswick, Canada Member No.: 1,653 ![]() |
I had the same problem, big oil leak from back end of tranny. I ended up taking it out of the car. I bought a tranny gasket & seal kit . I used a non hardening gasket dressing (loctite part# 2BR)along with the gasket between the inter. plate & housing. For the back cover I used Loctite form a gasket part# 26015. So far so good, I haven't seen a drop leak out. While I was at it, I also replaced every seal. Stephane |
Lo-Fi Version | Time is now: 5th July 2025 - 06:04 AM |
