CRAP! Bent injector., Stupid, cramped, tiny engine bay! |
Air_Cooled_Nut |
Sep 18 2005, 04:15 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Got my engine installed...and bent an injector (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Since working on this damn engine in its damn, tight fitting engine bay is a given, can the injector be replaced while the engine is still in the car?
Damn I hate the super-tight engine fitment (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Here's the left side with the #4 injector bent: Attached thumbnail(s) |
Air_Cooled_Nut |
Another view with torn hose:
Air_Cooled_Nut |
Sep 18 2005, 04:16 PM
Right side, how it should look:
JeffBowlsby |
Sep 18 2005, 04:19 PM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Pull the injector out and remount it. It looks like the injector is not bent, just pulled out from its big outer rubber seal. The injectors are easily replaced without removing the engine.
Air_Cooled_Nut |
Sep 18 2005, 04:22 PM
Sorry Bowlsby, Navy training coming out (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Slightly adjusted edit to original posts made (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) But it does really piss me off how friggin tight that four-cylinder lump has to be installed.
dmenche914 |
Sep 18 2005, 05:09 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
School of Hard Knocks taught me on 914 engine remove and reinstall to leave both injector rails off the head, flop them on top of the motor, else they can catch like you (and I) experienced.
It should be on the engine pull check list, remove injector rail before removing engine,and do not re-install until engine reinstalled. Hope the plastic injector body ain't cracked and you have a fuel leak (that was my Hard Knock). Give them a keen eye when you first prime the fuel system. cheers |
Rand |
Sep 18 2005, 05:51 PM
I just replaced my injector seals and fuel lines with engine in car. It wasn't a problem getting the injectors in and out. |
Air_Cooled_Nut |
Sep 18 2005, 07:03 PM
Dude, excellent idea! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) I was able to loosen the nut and move the injector back into position. Then locked it down and it held, yeay! I then replaced the torn fuel line. I was thinking, what about making those lines longer so they could more easily be pushed onto the intake runners and thus clear the body tin :scratch head icon here: |
Allan |
Sep 18 2005, 07:28 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) It is a bitch... |
type47 |
Sep 19 2005, 06:08 AM
when you're going to be working in the engine bay for a long time, remove the engine lid for a little more ease of access. it's only 2 10mm bolts
rhodyguy |
Sep 19 2005, 06:19 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
sounds like the rails got hung up on the suspension ears. next time, slide a piece of tin or an old license plate in between the engine tin and the engine shelve, at the rails. problem solved. this works for reinstalling the engine too. if you slot the 2 holes on the engine lid bracket arms, you can remove the engine lid without fully removing the bolts. it will just slide rearward. piece-o-cake putting it back in place by yourself too.
k |
Air_Cooled_Nut |
Sep 19 2005, 09:59 AM
Yup, did that! |
davep |
Sep 19 2005, 10:08 AM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I guess you will get lots of experience fitting the injectors. Especially now that you have to replace the incorrect hose clamps. You are just asking for an engine fire.
Air_Cooled_Nut |
Sep 19 2005, 12:21 PM
Though inexperienced at dropping the 914 motor I am experienced with the air-cooled VW motor. Never EVER a problem using the worm-style hose clamps to secure fuel lines -- both carb and FI. Your opinion and not one I share. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:40 PM |
