The reason why we use the correct fuel hose clamps |
JeffBowlsby |
Sep 18 2005, 04:39 PM
914 Wiring Harnesses Group: Members Posts: 8,532 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Someone asked the other day, and I just happened to have a sample of a fuel line hose I cut off recently that had both the correct flat-style FI hose clamp on one end, and the incorrect serrated-style hose clamp on the other. I dont know how long these clamps were installed (PO not me) but this is the resultant carnage...
Attached image(s) |
JeffBowlsby |
Sep 18 2005, 04:40 PM
Attached image(s) |
JeffBowlsby |
happy happy Joy joy...
Attached thumbnail(s) |
jimtab |
Sep 18 2005, 05:21 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
Jeff, I'm as dumb as a post when it comes to auto stuff but we use the "wrong" clamps in plumbing and air applications all the time without catastrophic failures, I don't understand how deforming the outer ply endangers the connection, even the "flat" clamp deformed the outer ply but in both pictures the inner ply(s) seemed to be ok....what am I missing...I have several of these clamps on my car.
DJsRepS |
Sep 18 2005, 06:26 PM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
What your missing is gas leaks caused by the hose getting loose as the hose squeezes and cuts its way through the serrated hose clamp. The flat OEM clamp although deforms the rubber hose lets no materal pass through it thus way less chance of gas leak or fire.
Allan |
Sep 18 2005, 06:49 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Yep. (IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) |
smooth_eddy |
Sep 18 2005, 06:57 PM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
My next project is to R&R all my fuel lines 100%. I can not find a source of FI clamps from my FLAPS that are stainless. Where can I find some? Eddy
Air_Cooled_Nut |
Sep 18 2005, 07:05 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
It looks to me like the hose clamps were tightened too much (too tight).
Tobra |
Sep 18 2005, 09:01 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Pelican is the only reasonable place that had nice hose clamps that I have seen, I am going to buy a sack at about a buck each |
rhodyguy |
Sep 19 2005, 05:51 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
a buck a piece @ the bird? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) no way. eddy, buy them by the box @ Williams Oil Filter Service in tacoma. fuel line too.
k Attached image(s) |
smooth_eddy |
Sep 19 2005, 05:57 AM
Thanks Kevin... (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Eddy
Tobra |
Sep 19 2005, 08:02 AM
but I am not in WA, will have to look at some similar local shops |
rhodyguy |
Sep 19 2005, 08:10 AM
for locals...WOFS also has the correct belts for the alt. 2 belts, 30 clamps, and 25' of hose was $105 and change. the per foot cost on the fl was still cheaper than the bird + no shipping costs. i asked if there would be a futher price break if i bought larger quantities. the answer was yes. is there any market for a correct clamp and hose package (not cut to length), postage (priority mail) included in the price? yes, i would make a few bucks for my time, gas, purchasing, and mailing.
k |
Cap'n Krusty |
Sep 19 2005, 08:17 AM
Those aren't the right clamps, either. The real clamps have turned up edges which further prevent cutting into the hose. The Cap'n |
rhodyguy |
Sep 19 2005, 08:20 AM
you are mistaken. the edges are rolled up. the camera goes out of focus when i zoom in. so it's hard to see. next comment.
k |
jonwatts |
Sep 19 2005, 08:33 AM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
It's hard to see in the picture cuz those clamps are so friggin bright they're like jewelry! Gotta get some of those, someday, when I need 'em. |
davep |
Sep 19 2005, 08:58 AM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Well, that is what happens when you use the wrong ones. You get into a nasty loop of tighten, extrude, leak, tighten, etc. Get my drift? Sometimes you get fire right after leak and before tighten can happen. Actually, to call those clamps is a bit of a misnomer because they fail to clamp after a short time. |
Mark Henry |
Sep 19 2005, 09:41 AM
I've tried those clamps and found they didn't clamp hard enough...you could still spin the hose on the fitting. Maybe they work on non-OEM hose but they suck on OEM. I haven't tried them yet but you can get the screw type with a teflon cover...Right now I have enough good wurth clamps for my needs. |
rhodyguy |
Sep 19 2005, 10:43 AM
they get plenty tight on the Gates fuel line.
k |
Tobra |
Sep 19 2005, 01:58 PM
Where, pray tell, did you obtain these nice, high quality clamps? Found these ABA Clamps Which look pretty nice. Bag of 50 for $55, which would be a good idea, as I need to have hose clamps for 7 mm fuel hose for two vehicles |
Lo-Fi Version | Time is now: 6th June 2024 - 02:58 AM |
