Bosch Part #, for 1.8L Fuel pump 74 |
qa1142 |
Sep 18 2005, 07:42 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Anyone know the part number?
Any chance this is it? 0580256996 |
qa1142 |
Sep 19 2005, 07:34 AM
94teener |
Sep 19 2005, 08:13 AM
Member Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 |
All 74 and earlier 914-4 cars came with Porsche Part Number
311 906 091 D ........... The number you have is probably a VW number. Phil |
VARam1500 |
Sep 19 2005, 10:01 AM
Newbie Group: Members Posts: 5 Joined: 16-September 05 From: Charlottesville, VA Member No.: 4,808 |
If you are buying a replacement........
I replaced the fuel pump on my '75 1.8 with a pump from Summit. It had the same specs, same size, and was less than half the price. Only difference was the output hose nipple was about 1/16" smaller. It's been working great. I'll tell you more if you're interested. --Case... |
Dave_Darling |
Sep 20 2005, 12:54 AM
Factory manual sez:
70-74 == 0 580 463 009 75-76 == 0 580 463 010 Doesn't matter if they're D-jet or L-jet, same pump. These numbers may have been superceded by now, though. But heck, as long as the pump can deliver 50 PSI and 12.5 gal/hour, it'll work fine. --DD |
VARam1500 |
Sep 20 2005, 10:32 AM
I think this is the one I'm using:
MSD Ignition Brand fuel pump at Summit Racing Also, I think it was the big end (inlet) that was a smidge smaller than the orignial instead of the output I said earlier. --Case... |
Cap'n Krusty |
Sep 20 2005, 10:42 AM
0 580 256 996 is NOT a good Boschnumber. The 311 906 091 D is the VW/Porsche part number for the early pump. The part you need is 61 316, the new number for the Vanagon, bus, and 75-79 bug. Even if you have an early car, a little replumbing and a new filter will get you on the road, and it's waaaaaaay cheaper than the early (and NLA, for the most part) pump. I would even risk a used one, as they rarely fail. Just don't buy one that's been sitting for a long time. The Cap'n
Lo-Fi Version | Time is now: 7th June 2024 - 09:47 AM |
