Tobra |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 ![]() |
I got to thinking after cleaning up my fuse block a bit and replacing my headlight relay. The connectors have a nice patina of age, because they are old. I remember seeing a commercial for this stuff that makes copper look shiny and new, has anyone ever tried this, and if so, how did it work?
I figure less resistance is better for 30 year old wiring, and shiny is better than dingy and green. |
Tobra |
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
any comments? Seems like a not too bad idea. |
Flat VW |
Illegal Soapbox Derby Racecar ![]() ![]() ![]() Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 ![]() |
I would be inclined to use a "true" electricial contact cleaning product, no need to "re-invent the wheel".
John |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
This stuff is the best...But it.s about $50. (Canadian) for a very small bottle. Lasts a long time though.
http://www.stabilant.com/bccomp.htm |
Tobra |
Looks like I could run down to NAPA and pick some of this stabilant 22 up when I get my butyl tape for the rear window. Should be good for cleaning up my grounds and contacts for my starter too. Thanks, you rock.
smg914 |
Sahara Beige Steve ![]() ![]() ![]() Group: Members Posts: 1,977 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None ![]() ![]() |
The contact cleaner I recommend is: De-Oz-Id
It comes in a small aerosol spray can. |
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
I've used CLR to clean electrical contacts. It works well, but I always make sure that it gets rinsed VERY well, as it is an acidic product and would probably make it worse instead of better if left on.
Lo-Fi Version | Time is now: 8th July 2025 - 03:14 PM |
