steering rack removal, can someone tell me how to remove the ra |
seanf123 |
Sep 19 2005, 07:25 PM
Newbie Group: Members Posts: 20 Joined: 1-January 05 From: san jose, ca Member No.: 3,384 |
i'm trying to remove the steering rack, so i can rebuild it. can someone tell me how it comes out. thanks
SpecialK |
Sep 19 2005, 07:38 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Been awhile since I removed mine, but IIRC you need to disconnect the U-joint where the steering shaft enters the firewall, detach the tie rods from the spindles, remove the two large bolts that hold the rear of the suspension beam to the body, and remove the two bolts that hold the steering rack to the suspension beam. I dropped the entire front end assy. when I took mine out, so it might be easier in the long run just to drop the whole front end...really not that bad of a job. If you mark the placement of all of the components prior to removal, you might get away without having to have it re-aligned.....emphasis on "might".
Cap'n Krusty |
Sep 19 2005, 07:42 PM
There's a link at the point where it meets the steering column. 1 bolt there. 2 bolts at the subframe. 2 tierod ends. In 32 years of professional P-car wrenching, I've never seen a worn rack on either a 911 or a 914, and I'm not sure parts are even available. You can replace/update the tierods without removing the rack. The Cap'n
seanf123 |
Sep 19 2005, 07:43 PM
thanx, thats a start. i already have the entire front end off. just have the rack left there
bondo |
Sep 19 2005, 07:47 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
The way I know of you just drop the whole front suspension, then it's obvious. I don't remember if you have to pull the gas tank, but I know the master cylinder has to come out to do it that way.
Now tell me how to rebuild the steering rack, because I've been told they aren't rebuildable. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Mueller |
Sep 19 2005, 07:55 PM
the bushings that the rack ride on inside are listed as seperate part number I believe, the problem is that if the rack is worn at the gears, it would be too cost prohibitive to have them built up and machined down.... if you need a new one, I'd try to find the lowest mileage unit I could find at the wreckers. |
watsonrx13 |
Sep 20 2005, 05:24 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Joe Ricard |
Sep 20 2005, 07:56 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Yea but getting it back in is tough if you don't have the gas tank out. Hard to get the shaft back into the bearing which is bolted to the body just under the tank.
Dang Rob, you becoming some sort of expert or sumpin. Nice documentation. You are doing me proud son. And last I talk to you your motor is running too! (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) |
jsteele22 |
Sep 20 2005, 09:30 AM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
Awesome web page! Are there other pages for any of the other projects you have listed ? I couldn't click on anything but the photos on that one page. |
watsonrx13 |
Sep 20 2005, 03:52 PM
If you go to the bottom of the page, you'll see Previous Update, Next Update, Return to Project Page, Return to Main Page. These links will allow you to move beyond the link I posted. BTW, if you use the link in my signature, it will take you directly to the home page of my web site. Joe, you've done me proud with the awesome rebuild of the motor. I'm working on installing the front disks/bearings, then the front and rear brakes. Soon, oh so soon, it will be back on all four wheels and mobile again..... |
Joe Ricard |
Sep 20 2005, 04:56 PM
And to think I was nearly going to go build engines for a living!!
These storms keep up and I still might. (IMG:http://www.914world.com/bbs2/html/emoticons/piratenanner.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 08:07 AM |
