Intake Manifold, Removal - Do's and Don'ts |
Maine914 |
Aug 5 2003, 01:53 PM
Member Group: Members Posts: 99 Joined: 30-January 03 From: Maine Member No.: 215 |
I am fairly sure the cause of some of my engine problems is a leak around the intake manifolds. I have downdraft dellorto carbs sitting on the top of them. I am planning to remove the manifolds and replace the gaskets. Are there any do's or don'ts you can suggest so I don't screw this up too badly? Such as remove it hot or cold [I assume its dead cold], what if any loosening chemicals to use [I've used PB Penetrating with success on other parts of the car], and any other tricks of the trade.
Thanks |
SirAndy |
Aug 5 2003, 03:03 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
shouldn't be a big deal. just make sure, once they're off, get some old rag and stuff it into the intake.
otherwise murphy's law will come around and kick you in the butt big time. it's a major PITA to get those nuts and washers back out of the intake, or, if they make it past the valve, you gotta have to remove the head ... Andy |
Jeroen |
Aug 5 2003, 03:05 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Use paper towels to close the intakes instead of rags
cheers, Jeroen |
SirAndy |
Aug 5 2003, 03:12 PM
QUOTE(Jeroen @ Aug 5 2003, 02:05 PM) Use paper towels to close the intakes instead of rags you mean like these? (IMG:style_emoticons/default/wink.gif) (IMG:http://www.sirandy.com/pix/914/work/007.jpg) paper towels don't "fussel" so they're better than a rag, unless you have a "fussel-free" rag handy, which is, of course, what i was referring to ... Andy |
Bleyseng |
Aug 5 2003, 04:03 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
"fussel"????
WTF is that, Andy. Geoff |
SirAndy |
Aug 5 2003, 04:07 PM
QUOTE(Bleyseng @ Aug 5 2003, 03:03 PM) "fussel"???? WTF is that, Andy. didn't know the word in english and was too lazy to look it up ... the \"fussel\" translated ... you know, those little "fuzzels" you get all over when using those cheap rags. Andy |
Jeroen |
Aug 5 2003, 04:31 PM
Regular rags posibly leave threads/pieces of rag (or fussel (IMG:style_emoticons/default/biggrin.gif)) inside the intake port (and into the cilinder), which could cause damage...
If this happens with paper towels, it will just disolve in the oil, without ill effects Ofcourse you won't have this problem with "fussel-less" rags I hope this isn't too confusseling (IMG:style_emoticons/default/biggrin.gif) cheers, Jeroen |
Aaron Cox |
Aug 5 2003, 04:34 PM
this is so fussel-strating to try and understand! (IMG:style_emoticons/default/laugh.gif)
seanery |
Aug 5 2003, 04:36 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,852 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
fuzz
MarkV |
Aug 5 2003, 04:41 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Lint or fuzzies but never fussels (IMG:style_emoticons/default/w00t.gif)
Unless you are applying WD-40, in which case fussels don't matter. |
Maine914 |
Aug 5 2003, 07:18 PM
"Foozle" is a bungling golf stroke.
"Fusel" is bad liquor. "Fussle" is now a tendency to slowly disintegrate. Send it to Webster's. Thanks for the advice. Sounds like easy surgery...just don't leave anything inside. |
tryan |
Aug 5 2003, 08:49 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
lint-free. no fizzle....fo shizzle.
to fussle your brain on fusel will make you foozle. is that teenbonics or what? |
Aaron Cox |
Aug 5 2003, 08:51 PM
um... No on the teenbonics. thats called SNoop-onics or ebonics. not just limited to the teens (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 22nd May 2024 - 10:19 PM |
