| 914zim |
Sep 24 2005, 01:51 PM
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Dudes:
Ok, I'm trying to replace my alternator belt, but I need to remove the air injection pump stuff before I can put the belt on. The pump has been missing since I've owned the car, but the pulley and mounting hardware is still on the car. Once I remove this stuff, I'm not going to put it back on. I don't need it. I've removed the 3 bolts holding the "tripod" mounts that the pulley is attached to, but it still won't come off. It looks like there are 3 more bolts down near the center of the fan that might need to come off in order to take this whole assembly out. Can anyone confirm this? These bolts look like they'll be a bitch to get out, so I want to make sure they definately need to come off before I go through all the hassle. I'm assumming there is another bigger bolt that actually holds the fan on, maybe under the "tripod" assembly? Any help on this is greatly appreciated! Thanks, Andy... |
| bd1308 |
Sep 24 2005, 01:57 PM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
using a mirror of sorts....can you grab a picture?
| Cap'n Krusty |
Sep 24 2005, 02:53 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
The 3 x 6mm bolts on the legs of the bearing carrier hold the bracket in place.
The 3 x 8mm bolts on the fan hold the fan and the air pump drive to the hub, which is in turn bolted to the crankshaft. They're probably 13 mm wrench size, but they MAY be 6 mm triple square. Yes, you have to remove all 6 bolts. If you remove the fan, or it falls off, you have to be careful to index it properly when you reinstall it. The Cap'n |
Lo-Fi Version | Time is now: 17th March 2026 - 07:41 AM |
