oil pressure light, wtf? |
ChrisReale |
Sep 24 2005, 07:55 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Last night I was driving and my idiot light came on. I pulled over and checked the dip stick and it was in fact low. I put oil in, and the dip stick read fine, but the idiot light was still on. Where can I troubleshoot this issue. I am not driving until I figure this out. Thanks
qa1142 |
Sep 24 2005, 07:57 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Replace sender first. they go bad, if that is not it, you may have to go into engine
smooth_eddy |
Sep 24 2005, 08:16 PM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
same thing happens to me when I am a quart low. When I corner hard the light comes on for 30 seconds or so. Then goes off. Add a quart first to see if that cures your problem. Eddy
Type 4 Unleashed |
Sep 25 2005, 02:46 AM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Partially If, a new sender, doesn't take care of the problem, and your budget, doesn't currently allow you to to do a re-build, you can replace the front oil pressure relief spring, with a used one out of a type 1, they are about an 1/4" longer than the type lV, and your oil pressure will be boosted about 20 psi. And you can run, a half a quart over (oil), that helps in the cornering. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:49 AM |
