Quick Release Hubs, Who is using what? |
Targa |
Sep 27 2005, 04:10 PM
V Member Group: Members Posts: 180 Joined: 26-December 02 From: San Mateo, CA Member No.: 18 |
All I know is that I should get a fine splined hub rather than a coarse one. Opinions, prices, what's the hot ticket?
ArtechnikA |
Sep 27 2005, 04:15 PM
i got mine from here. okay, silly name, good product, good price. i got what they now call the "Type 1A"
$100. i like it. i'm actually using a Momo wheel on a Personal hub to get the spacing i like. |
Jeroen |
Sep 27 2005, 04:22 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
the one Rich mentioned is nice and it's hard to beat for the price
paragon also has a nice QR, a little more expensive OGracing has a QR that doesn't require a hub (the splined part bolts straight to your steering shaft) what type of wheel and hub are you using? |
Targa |
Sep 27 2005, 04:39 PM
A MOMO Prototipo. What else! Thanks for the replies. Do you happen to have the link to the QR hub that bolts to the column? |
Jeroen |
Sep 27 2005, 05:04 PM
http://www.ogracing.com/eshop/home.asp?categ=164
It's the second one, but I think it's a bit crude for a street car works on a track car |
messix |
Sep 27 2005, 05:42 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
i'm intested in one too, but.. is there much play in the quick release? are the ball bearing ones better than the splined one for slop or play?
Mueller |
Sep 27 2005, 06:02 PM
sick question (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
anyone use a stock wheel with a QR?? I kinda like my stock wheel (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Joe Bob |
Sep 27 2005, 06:03 PM
I have one....bought it from Iverson when he said it had too much play...doan bother me. You doan have a horn....or it's gonna be a PITA to do so....
ArtechnikA |
Sep 27 2005, 07:05 PM
1) not mine, donno about others. 2) you'd think a bearing version would be better at compensating for wear than splines. i've had mine off maybe a dozen times. if it went on and off a dozen times a weekend in a track (dusty, gritty...) environment maybe there'd be more opportunity for wear, but with reasonable exercise you're not going to experience any, IMO. BTW - my horn button works just fine. you -do- have to pop the button and disconnect the wire if you're going to use the QD feature. if i were doing more track events where i had it on and off a lot, i might find an alternate horn actuation mechanism. PA requires an operable horn on a street car. frankly, i've seen enough clueless people in race track paddocks that IMO a horn is a good idea on a track car too. |
xitspd |
Sep 27 2005, 10:23 PM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
Attached image(s) |
JWest |
Sep 28 2005, 03:25 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
I use this one (removed at least 4 times a day to get in and out of the Scheel seat) Tekniq Snap-Off.
It has horn contacts built in, and tapered pins that will adjust for slop. I got the the street legal verison since it was cheaper than the track version (not sure why) and I easily removed the lock cylinder (since, as I said, I remove the thing at least 4 times a day). |
campbellcj |
Sep 28 2005, 11:06 PM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I have the Tekniq 'race' version and it is awesome; no slop and easy to install and use.
Jeroen |
Sep 29 2005, 05:10 AM
I've got the one from http://www.tcracing.org
Same as the Tekniq racing version Drawback on those is that they don't fit a momo hub I already had a correct hub to fit it to, so it wasn't a problem for me Above, I mentioned Paragon They sell the exact same QR but one that does fit a momo hub |
ottox914 |
Sep 29 2005, 06:51 AM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
I've got the teknic street and love it. Left the lock system working. Thats a PLUS on a street car. Quick trip to the Dairy Queen? Leave it locked, slither in and out of your car, you're good. Gone from the car longer, want some "security", pop it off and in the trunk. Track day? Using the key takes just seconds longer to unlock and release. I got the version that uses the momo hub, and so requried an adaptor to make it all work. This moved the wheel back maybe 1 inch, which I like better for my personal preference of driving position. Very happy customer. And the horn still works.
Lo-Fi Version | Time is now: 1st June 2024 - 06:16 PM |
