> Calling Thomas, are you out there?, I need some Transmission help
skline
post Sep 30 2005, 05:37 PM
Born to Drive
This is not off topic and it does contain 914 content! Thomas, Richard came over today to help with my car and found out why the speedo doesnt work. The end gear that drives it inside the tranny just spins freely like it is not connected to anything. I have another complete end cover with gear and everything but need your help and a gasket to swap it out. It would really be nice to have a working Speedo again. Besides, I want the end cap off so I can see howcome the speedo drive doesnt work. It never worked from the day I put it in. Call me!!
Replies(1 - 19)
Aaron Cox
post Sep 30 2005, 05:39 PM
Professional Lawn Dart
MY guess, (when i saw you install it)
the gear didnt line up when you hammered it in.
guessing you bent the brass gear on the shaft... ( ihave an extra one here i think)
just drive out the pin, and put a new gear in, put a new pin in...
skline
post Sep 30 2005, 05:42 PM
Born to Drive
It is not connected to anything inside the tranny, has nothing to do with me having to hammer it in. The gear is a little buggered but it didnt break it.
JoeSharp
post Sep 30 2005, 05:43 PM
In Irvine, Ca. May 15-18
Scott: Thomas is under the weather at this time, but I'm sure we have what you need. Just come by.
:PERMAGRIN: Joe
bondo
post Sep 30 2005, 05:45 PM
There's a pin that holds that gear to the stretch-bolt that holds the pinion shaft together. Typically you don't mess wit that when rebuilding a trans. A deep socket fits over it and you just keep it all together. Chances are something broke, either the brass shaft or that pin. If the right angle drive isn't installed just right it can bind, which may have caused the problem.
skline
post Sep 30 2005, 05:48 PM
Born to Drive
You must be talking about this one. Aaron, this picture was taken for you just now.
SLITS
post Sep 30 2005, 05:49 PM
"This Utah shit is HARSH!"
Are you testing the end gear shaft by turning it at the right angle drive? If you are, remove the right angle drive and look at the engagement tab....it could be broken off.
And before you stick A-aron, clean your fingernails.
skline
Born to Drive
QUOTE (Joe Sharp @ Sep 30 2005, 04:43 PM)
:PERMAGRIN: Joe
Well, I was hoping it could be done in the car so I dont have to remove the transmission again. It is really a bitch with the muffler in there.
skline
post Sep 30 2005, 05:51 PM
Born to Drive
QUOTE (SLITS @ Sep 30 2005, 04:49 PM)
Nope, angle drive is out, I can reach up inside and turn the gear freely with no resistance at all like it is not connected to anything.
SLITS
QUOTE (skline @ Sep 30 2005, 04:49 PM)
:PERMAGRIN: Joe
You can pull the end cover without removing the tranny...it's easy!
Aaron Cox
post Sep 30 2005, 05:53 PM
QUOTE (skline @ Sep 30 2005, 04:48 PM)
thats the one!
Aaron Cox
post Sep 30 2005, 05:55 PM
BTW - is that a promise, a threat, or a shower toy scott? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
BTW - like i said, and bondo said.... you had to have fubar'd the gear....
pull the end cover (trans supported by jackstand)
and pull it off... and take a look.
AA
Dr Evil
Send me your transmission!
Grumpy Scott?
I remember the first time that I diagnosed that problem for you...with the same conclusion (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Gettin a bit long in the tooth, eh?
Is there a gear in the end of your angle drive that mates to the one next to your puny finger? If you turn it it should turn the out put blade on the angle drive. If not, then pull the internal gear out and look at it. Interesting.....
Oh ya, I'm supposed to be studying.
...the profunda brachii artery eventually turns into the radial collateral artery on the lateral aspect of the humerus..... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Aaron Cox
post Sep 30 2005, 05:56 PM
thats richards finger.... not scotts....
scotts nails are painted (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Dr Evil
post Sep 30 2005, 05:57 PM
QUOTE (skline @ Sep 30 2005, 04:51 PM)
Busted pin? Need to take off the cover...get'er done.
Dr Evil
QUOTE (Aaron Cox @ Sep 30 2005, 04:56 PM)
SLITS
post Sep 30 2005, 05:59 PM
QUOTE (Aaron Cox @ Sep 30 2005, 04:55 PM)
AA
Wrong camel breath...
Car ass end high on jackstands.......tranny supported on main case with jack....remove tranny mount bolts / ground strap.....lower tranny slightly....remove end cover.
If the angle of the ass end is steep enough...you might not even have to drain the tranny.
skline
post Sep 30 2005, 06:00 PM
Born to Drive
No Aaron, I couldnt go with you and your boyfriend yesterday to get them done, I had a date with a hot Mexican woman so they never got painted like yours. Good try though. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Aaron Cox
post Sep 30 2005, 06:02 PM
QUOTE (SLITS @ Sep 30 2005, 04:59 PM)
BTW - is that a promise, a threat, or a shower toy scott?  :lol:
AA
thats what i said you senile swine!
lol...
support BY a JACK or JACKSTAND. and OF COURSE remove all things associated with the REAR COVER before REMOVING the REAR COVER
Can i get a side of attitude with my order please? (IMG:http://www.914world.com/bbs2/html/emoticons/flipa.gif)
SLITS
post Sep 30 2005, 06:03 PM
Scott should buy a Honda...................with unpainted ground effect fiberglass body panels and a 5 lb fart can exhaust.
- Lo-Fi Version Time is now: 13th July 2025 - 05:02 PM
