door gap, how big should they be |
grasshopper |
Oct 9 2005, 06:42 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
ok, put the 914 on jack stands today, with a 2x6 underneath of each, to level the car out. I think it worked pretty well. Is the gap big enough now, to weld in a brace, before i replace the longs, or should it be bigger. I compared it to the other teener, and they look to be close to the same. Here is the before.....ignore the big hole next to it. I did some work today, that i am pretty pleased with (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Attached image(s) |
grasshopper |
after
Attached image(s) |
grasshopper |
Oct 9 2005, 06:43 PM
how is that?? bigger?? Thanks
Lou W |
Oct 9 2005, 06:48 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
Looks better in the second picture. I think in the Classic section, you can find the factory dimensions to get the gaps right. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
grasshopper |
Oct 9 2005, 06:53 PM
here is a pic of it up on jack stands
Attached image(s) |
GWN7 |
Oct 9 2005, 07:05 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
You can check the gap Here It gives all the measurements. Good luck. It looks like your off to a good start. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
qa1142 |
Oct 9 2005, 07:15 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
I bet mesurement from windshield fram to targa bar would be best for your issue.
grasshopper |
THANKS (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
michelko |
Oct 9 2005, 10:54 PM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Hi Grasshoper,
be aware that putting in some heat into the tub will make it shrink a little bit. You have to adjust a little more gap then you want after Welding. I went fine with about 3-4 mm plus with my Hell Hole restoration. Not sure if this is also the right amount for your project (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
SirAndy |
Oct 9 2005, 11:04 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
he's right ... you can add some bracing (see attached pic) before welding to prevent the tub from tweaking ... also, you should consider removing the top and adding a "X" brace between the targa bar and the windshield hoop. attach it where the targa latches are and the sunvisor mounts ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy Attached image(s) |
grasshopper |
Oct 10 2005, 07:34 AM
Thanks guys!!!! im going to start fabricating those braces today!!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Dead Air |
Oct 10 2005, 10:38 PM
Senior Member Group: Members Posts: 1,268 Joined: 9-May 04 From: Buffalo, NY Member No.: 2,042 |
[QUOTE] All I can see is a big GASH in the quarter panel. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:23 AM |
