| Rand |
Oct 11 2005, 01:35 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
After having my second door handle break, I decided to do something different.
I made a lever out of a piece of tubing. Drilled a hole through one end that fits over a pin that I welded to the door. Flattened the other end and smoothed it out. (IMG:http://www.914world.com/bbs2/uploads/blog-1129058039.jpg) Welded a hook to the lever that goes inward. A wire loop runs between the hook and the release latch inside... (IMG:http://www.914world.com/bbs2/uploads/blog-1129058030.jpg) Lift up on the lever to open, the spring returns it to the bottom stop... (IMG:http://www.914world.com/bbs2/uploads/blog-1129058052.jpg) Weld a piece of sheet metal across the surface to shave the door handle, and the crude design is hidden for a clean look. Keeping the recess behind the door makes it convenient to reach a finger behind and lift the latch. It releases easier than ever and won't break. (IMG:http://www.914world.com/bbs2/uploads/blog-1129058021.jpg) (Ok, I figure someone will ask, so... No, I don't miss the door locks. I never lock the doors. I keep valuables locked in the trunk and have a hidden ignition cut off switch for theft protection. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ) |
| Mueller |
Oct 11 2005, 01:41 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
pretty ingenious !!!!!
I like it....the wire looks a little on the thin side..... |
| Rand |
Oct 11 2005, 01:43 PM
Yeah, the wire in the photo seems a bit hoaky. I was planning on making a nicer piece there... maybe washers welded to the ends of a piece of small rod. But it lifts so easily that my temporary wire isn't stressing at all. Maybe I'll get around to upgrading that piece later. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
| URY914 |
Oct 11 2005, 01:48 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,300 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
And we wonder why people say 914 owners are cheap?
Good work, the factory should have done that in the first place. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Paul |
| Tobra |
Oct 11 2005, 02:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Frugal, not cheap.
You keep valuables in your car? Right now, my tires are the most valuable thing in the vicinity of my car. |
| Air_Cooled_Nut |
Oct 11 2005, 02:47 PM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
What do you do about securing the car (un/locking doors)? Guess you could use a remote entry system (and pray the battery never dies...).
| Air_Cooled_Nut |
Oh, but neat idea! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
| Rand |
Oct 11 2005, 03:52 PM
I don't miss the door locks. I have never locked the doors. I keep valuables locked in the trunk and have a hidden ignition cut off switch for theft protection. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
| ClayPerrine |
Oct 11 2005, 05:23 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
That looks really cool!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
| horizontally-opposed |
Oct 11 2005, 05:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
This is an idea with some legs on it...
Nicely done! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) pete |
| firstknight13 |
Oct 11 2005, 08:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
great idea to bad VW oops i mean PORSCHE didn't think of it first (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
| davep |
Oct 11 2005, 09:16 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,362 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Idiot grandson did that to his Civic. Honda says you have to open the hood from inside the car. So if the cable breaks then you have to use a can-openner? I figure any self-respecting car jacker would take 15 seconds to get in. But I'm in no hurry to retrieve the car. |
| mharrison |
Oct 11 2005, 09:27 PM
Why do I bother???? ![]() ![]() ![]() Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
Typically a solenoid type keyless\handle-less entry system has a "Hidden" button for a manual release. Anyone who puts one of those on their car (Honda or whatever) should always incorporate this.
Lo-Fi Version | Time is now: 14th April 2026 - 05:04 PM |
