Alt light on, Alt light on when lights on |
rudedog7 |
Oct 13 2005, 01:20 PM
Newbie Group: Members Posts: 5 Joined: 2-April 03 Member No.: 504 |
Help me! This just started happening, when my headlamps are turned on the red alt light stays on. When I hit the brakes the light gets brighter. When I hit the left turn signal the signal beats very rapid, the right side it fine. Then some times the turn signals just don't come on at all. This started after I had a fuse blow on the fuse block. Any one got any clues? 1973 914-4 1.7L
bd1308 |
Oct 13 2005, 01:49 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
I would check the what....#7 fuse? Make sure they are ALL corrosion free....and seated very well inside thier little holders.
funny thing, if you unplug the #7 (or is it #8) fuse, the alternator light will come on and will not go off...so maybe it's a corrosion issue there.... also, check your grounds. I believe one grounding point is somewhere near the fuse panel, but there's also one in the engine compartment, on the firewall near the alternator. b |
Allan |
Oct 13 2005, 01:59 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
#8 fuse... |
rudedog7 |
Oct 14 2005, 10:43 AM
Thanks for the advice, I'll check for good connections and clean the contacts.
Lo-Fi Version | Time is now: 7th June 2024 - 02:31 PM |
