Electrical Troubleshooting, help needed =/ |
dlo914 |
Oct 13 2005, 10:40 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
hooked up everything on the car, but now im not getting power to certain areas of the car. started probing around w/ a test light. discovered power at the starter, but the car doesnt turn over. probed around the fuse box and discovered the following (view image below). As for the fuse box what are the correct fuses for each accessorie and what does each fuse control? Thanks in advance (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Attached image(s) |
McMark |
Oct 13 2005, 11:13 PM
Fuses 1,2,3,4 are the high/low beams for left & right. So they'll have power when you turn on the headlights and flip between high and low beams. Looking up the other two now...
Rand |
Oct 13 2005, 11:14 PM
McMark |
Oct 13 2005, 11:16 PM
8 - Fresh Air Fan, Wipers, Lighter, Horn
9 - Stop, turn, backup lights. |
dlo914 |
Oct 14 2005, 12:01 PM
Thanks!
messix |
Oct 14 2005, 12:21 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
key in start position you should have power at the starter solenoid. that will come from the ignition switch. do you have a haynes manual? get one it has the wiring diagrams for these. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:22 PM |
