whats ths for on my six??, strange appendages |
thesey914 |
Oct 15 2005, 04:22 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
What is this electrical contact for on the carb for?
Attached image(s) |
thesey914 |
Oct 15 2005, 04:24 PM
And this weird arrangement??
Attached image(s) |
thesey914 |
Oct 15 2005, 04:25 PM
on carbs
Attached image(s) |
thesey914 |
Oct 15 2005, 04:26 PM
My guess something to do with sporto? used to be hooked to a sporto 'box.
sixnotfour |
Oct 15 2005, 04:35 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
The valve is for a sportomatic clutch release. The motor also looks to have Zenith carbs .
I bet that is a 70-71 911T motor with sportomatic transmission. darn euro 2.4 This post has been edited by sixnotfour: Oct 16 2005, 12:35 AM |
thesey914 |
Oct 15 2005, 04:40 PM
Correct -2.4 with zeniths. So I can bin all this stuff and block-off where necessary? There is also the pump on the end of the cam that I'll be looking to block off.
markb |
Oct 15 2005, 04:45 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
You might want to save those parts. I don't think they're real common. Of course, I've been known to be wrong. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Cap'n Krusty |
Oct 15 2005, 05:16 PM
THe electrical connection is for the decel circuit, removed on a great many cars. The vacuum plumbing is for a sportomatic (note the spelling) and can be removed and blocked off. The fittings should unscrew from the manifolds, and suitable plugs can be installed. The pump can be removed from the cam tower, and a stock "freeze plug" installed. Even easier, you can just leave it open, assuming the camshaft oil seal is in good shape. The Cap'n
thesey914 |
Oct 16 2005, 02:00 AM
Thanks for the info gents! Who says the fibre of 914club has deteriorated?(nobody actually said that (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) )
Guys like you are the backbone of this club (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
thesey914 |
Oct 19 2005, 04:01 PM
A question for the capt..This decel circuit for fuel economy or emisions?
I take it thats what this electrical conection is for on the left carbs? Attached image(s) |
thesey914 |
Oct 19 2005, 04:09 PM
Another question...where's the tach sending wire? Is it attached to the distributor?
I'm just in the process of removing all the engine wiring harness -I'll run fresh wire for tacho, alt, oil pressure (dont seem to have an oil temp sender fitted?) I'm thinking black/purple wire is for tacho other wire to distributor is for the CDI ? Attached image(s) |
davep |
Oct 19 2005, 04:12 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
That black wire with purple stripe is usually the tach wire on a 914/4.
ArtechnikA |
Oct 19 2005, 04:57 PM
yes. |
thesey914 |
Oct 20 2005, 01:17 AM
Decel circuit anyone??
What do most people do with their relay boards? I've seen a few conversions with it left in place...looks like it would get in the way of the tank to me. Thanks in advance. |
ArtechnikA |
Oct 20 2005, 05:22 AM
fits ok on the factory 6's ... |
Lo-Fi Version | Time is now: 8th June 2024 - 04:15 AM |
