> PAINT STRIPPING, SOME KIND OF JOKE!!!
TINCAN914
post Oct 22 2005, 11:15 AM
Summer's Commin...
OK so I went down and got some aircraft stripper this morning. Reading and taking everyone's suggestions, based on previous posts. THis is some kind of joke right? THis is something everyone plans for the newbies?
It is coming off but with three layers of paint good god what a pain in the ass.......
I sear there is 12 coats of paint ifthere's one!!! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
To top it off. I'm having the carpet cleaned, and the guy is running the hoses through the house, and then out the garage. He is finishing up and while winding his hoses, he knocks over the pan I'm using to brush the stripper on the car with, and the can of the stripper. Dragging the drop clothes the length of the garage!!!!
Is everyone stupid around the country, or just in California!!!
Deep breath!!!!!!
mmmm ok...Back to work.....
Replies(1 - 19)
McMark
post Oct 22 2005, 11:44 AM
914 Freak!
Nobody said it was easy, but it is the easiest. I.E. least manual labor. Have Fun Newbie! (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
SpecialK
post Oct 22 2005, 11:46 AM
aircraft surgeon
The "aircraft stripper" works great on smaller parts, but I can imagine stripping an entire car with it. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
This is gonna sound kind of hokey, but I'm using (or used a month or so ago for an experiment) a set up that I rigged for sanding the drywall mud in my house to lessen the amount of dust created by this process. I tried just hooking my shop vac to the sander with a length of hose, but the filter in the shop vac clogged within seconds from the super fine mud dust........so "plan B". I saw one of these at Lowe's, but couldn't see paying $40 for something so simple.
I'll see if I can describe it so I don't have to drag all of the crap out for a pic...I've got a 1/4 sheet Porter/Cable electric palm sander with a dust collector port (works fine on small projects, but clogs up fast). I ran a 1" dia. hose (15' long) from the collector port on the sander, into a spare 5 gal. bucket (old 'mud' container w/lid [hole in lid for inlet hose from sander, and enough hose fed through the lid to reach the bottom of the bucket]), filled the 5 gal. half way with water, cut another hole in the lid for my shop vac hose to fit through (tight fit, only inserted a couple of inches to prevent it from sucking water).
So here's what happens.....You switch on the shop vac, the shop vac sucks on the bucket drawing on the hose that goes to the sander collector port (think big waterpipe (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) ). The dust gurgles through the water in the bucket retaining a significant amount of the dust. Any dust that escapes the "water trap" is then filtered by the shop vac.....virtually no dusty mess created by sanding the car. And the shop vac filter lasts much longer before replacement is required.
(IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
J P Stein
post Oct 22 2005, 11:51 AM
Irrelevant old fart
I had up to 6 color coats on my shitbox.....now that'll make you cry. It took me about a month & a half to get the shit off.
J P Stein
Irrelevant old fart
anuther
J P Stein
post Oct 22 2005, 11:53 AM
Irrelevant old fart
again
J P Stein
Irrelevant old fart
just one color coat here
McMark
post Oct 22 2005, 11:54 AM
914 Freak!
QUOTE (Buzzard1 @ Oct 22 2005, 09:46 AM)
You just pretty much described how an oil both air filter works. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Nice work.
SpecialK
post Oct 22 2005, 12:15 PM
aircraft surgeon
QUOTE (McMark @ Oct 22 2005, 11:54 AM)
The "aircraft stripper" works great on smaller parts, but I can imagine stripping an entire car with it.  :huh:
So here's what happens.....You switch on the shop vac, the shop vac sucks on the bucket drawing on the hose that goes to the sander collector port (think big waterpipe  :toke: ).  The dust gurgles through the water in the bucket retaining a significant amount of the dust.  Any dust that escapes the "water trap" is then filtered by the shop vac.....virtually no dusty mess created by sanding the car.  And the shop vac filter lasts much longer before replacement is required.
Didn't think of it that way......don't have one on my car.
OH!! I forgot to mention in the "description". I drilled a shitload of holes in the part of the hose that is submerged in the water to make the bubbles smaller......it worked much better after I did that.
TINCAN914
post Oct 22 2005, 12:48 PM
Summer's Commin...
Six Coats???? Oh man.. It appears that I have three seperate layers of white. Multiple coats of primer etc.
It looks like I will need to apply three different applications before it's down to metal. I guess it's a hell of a lot easier then sanding!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Aaron Cox
post Oct 22 2005, 12:51 PM
Professional Lawn Dart
QUOTE (bmunday @ Oct 22 2005, 11:48 AM)
oh brian, i talked to your wife, she said you offered to strip mine too!
ill be over at 3PM (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
TINCAN914
Summer's Commin...
QUOTE (McMark @ Oct 22 2005, 09:44 AM)
Nobody said it was easy, but it is the easiest.  I.E. least manual labor.  Have Fun Newbie!  :lol2:
Blow me.... (IMG:http://www.914world.com/bbs2/html/emoticons/flipa.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Mark if you want to drive down from up North, you can help me out... All the burgers you want.....
John
post Oct 22 2005, 12:58 PM
member? what's a member?
It sounded like some sort of power BONG. Leave it to you Calyfornya types to think that one up.
Cyclonic dust seperators work on a cyclone principle allowing the dust to settle out toward the middle of the cyclone.
Hmmmm. We do have lots of tornados in these parts.
Perhaps things are invented depending on what you are used to....
I have stripped entire cars with aircraft stripper. Do a panel at a time and don't let that crap dry or it gets tough to get it off.
good luck
just my $0.02
TINCAN914
post Oct 22 2005, 01:50 PM
Summer's Commin...
QUOTE (Aaron Cox @ Oct 22 2005, 10:51 AM)
It looks like I will need to apply three different applications before it's down to metal. I guess it's a hell of a lot easier then sanding!!!!  :headbang:
Up yours!!
Smart ass. (IMG:http://www.914world.com/bbs2/html/emoticons/finger.gif)
TINCAN914
post Oct 22 2005, 01:54 PM
Summer's Commin...
QUOTE (JOHNMAN @ Oct 22 2005, 10:58 AM)
good luck
just my $0.02
Started with a 3'x3' section as suggested, I think it did let it dry to long. I have been giving it 45 mins per application. I will try giving 30 to see if that improves the end result.
SpecialK
post Oct 22 2005, 01:58 PM
aircraft surgeon
QUOTE (JOHNMAN @ Oct 22 2005, 12:58 PM)
good luck
just my $0.02
I'm from Denver (The Mile High (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) City), did a 4 year tour-of-duty in San Diego (no (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) allowed by Uncle Sam (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) ), and now reside in the Meth capitol of the universe (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) (I'll pass on that.....gimme another beer, thank you (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) ).
For you JOHNMAN:
http://modernduck.com/bong/
jd74914
post Oct 22 2005, 02:42 PM
Its alive
QUOTE (Buzzard1 @ Oct 22 2005, 02:58 PM)
I'm from Denver (The Mile High  :toke:  City), did a 4 year tour-of-duty in San Diego (no  :toke:  allowed by Uncle Sam  :( ), and now reside in the Meth capitol of the universe  :angry: (I'll pass on that.....gimme another beer, thank you  :beer1: ).
and your name used to be "special k" (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif)
Aaron Cox
post Oct 22 2005, 02:51 PM
QUOTE (jd74914 @ Oct 22 2005, 01:42 PM)
ketamine (sp) isnt meth....
but still funny (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Crazyhippy
post Oct 22 2005, 03:15 PM
Insert witty comment here...
So where's the stripper party gonna be held? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
B can work on his car in the parking lot, while everyone else is inside... uhhhh recruiting new non-club members (or trying to get non club members to play w/ members members (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) )
You didn't expect this to be easy did you B?
BJH
TINCAN914
post Oct 22 2005, 03:21 PM
Summer's Commin...
Eating lunch now,,, Still working on the hood.. SSSSSSSSSSSHHHHHHHHHHHEEEEEEEEEETTTTTTTTTTTTTTT!!!!!!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Easy BJ no, but mmmmmaaaaannnnnn !!
Stripper party, oh that's at Aarons house, he insists like dressing up as little red riding hood and stripping down to his uummm, well you know.. (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif)
Bring your ones.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
- Lo-Fi Version Time is now: 16th July 2025 - 02:16 PM
