9 & 10 " rims on rear? |
retrotech |
Oct 23 2005, 01:12 PM
retrotech Group: Members Posts: 470 Joined: 2-November 03 From: Mosier, Oregon Member No.: 1,302 |
I need to see as many pictures as I can of 9 & 10" rear rims on 914's that do not have the standard 916 flare. Rear view.
I have a narrow body that I want to use 9/10" rims, I want to alter the fender as little as possible. My biggest concern is how much wheel protrudes at front & rear rocker panel. Thanks |
SirAndy |
Oct 23 2005, 01:17 PM
Resident German Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
good luck, you'll need more than just a BFH .... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy |
retrotech |
Oct 23 2005, 01:24 PM
What is a BHF?
soloracer |
Oct 23 2005, 01:33 PM
Senior Member Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 |
Big F'n Hammer
retrotech |
Oct 23 2005, 01:41 PM
I know there were some guys that fabricated, or modified their fenders for these size rims, with out using the "bumps".
They are who I am hoping to hear from, with photos. |
Dr. Roger |
Oct 23 2005, 02:17 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Thanks Retrotech for posting this ad. As you might know, I also have a keen interest in how to go about this. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) So far the pie slice method seems to be an OK way IMHO. (in my humble opinion). I'm a hack fiberglasser and am fantasizing about bending an outer lip, out of tubing, and welding it to the existing fenders. Then cutting out what fender material I don't want, then bonding the glass from the fender to my tubular lip. Pulling the glass taught from the outer parts of the fender so as to have an linear flare. Starting from right behind the door jambs straight to the new lip. Not 4 humps sticking out. More like abc914's rear fenders. Or is he 914ABC? I forget.... (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) This should be a great thread.... (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
sixnotfour |
Oct 23 2005, 02:27 PM
914 Wizard Group: Members Posts: 10,437 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Here is some steel fenders. I dont know if he sells em seperate or not, but sounds like what your looking for;
http://www.tangerineracing.com/Flares.htm |
J P Stein |
Oct 23 2005, 04:05 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Rich Bontempi's flares.
Attached thumbnail(s) |
J P Stein |
Oct 23 2005, 04:06 PM
nuther view......those are 10 X 16 wheels & 10 inch tiars.
Aaron Cox |
Oct 23 2005, 04:47 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
a 205 on a 6" barely fits.
a 205 on a 7" requires minimal persuasion to fender. a 225 on a 7" requires a good inch or 2 of pulled fender a 225 on an 8" requires flared qrts, and more rolling (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) (mad at my flares right now) every inch beyond a 6" is added all outboard. you want a 9" wheel and tire.... say 3+ inched out, and continue the flare at least 3 inches above the lip |
Mueller |
Oct 23 2005, 05:13 PM
unless you have 35mm offset rims like Mike (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) stock fenders with enough breathing room between fenders and tires.....a 225 would rub with my rims.... other than that, good descriptions Aaron (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) |
Aaron Cox |
Oct 23 2005, 05:20 PM
hehehe - no prob mike i had to baseball bat my flares today. the 225's on 8's were rubbing. i fubard them up good. nothing Los Panchos cant fix AA |
Lo-Fi Version | Time is now: 12th June 2024 - 06:40 PM |
