clutch problems... |
Mueller |
Feb 10 2003, 04:28 PM
installed new clutch cable...
on the transmission side of the cable, the nut is at the maximum threaded portion (tightened as far as possible) yet I could not get the clutch to release when pushing the pedal...so, I added a 1 inch spacer between the nut and the clutch fork... now the clutch will desingage but it feels odd when pressing the pedal... when I push the pedal I cannot feel any thing loose inside the tunnel to signify a loose clutch tube cable... what am I missing? I thought that if the clutch tube was broken that I would be able to feel it being loose inside the tunnel (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/blink.gif) Thanks Mike |
Oled |
Feb 10 2003, 05:03 PM
Newbie Group: Members Posts: 44 Joined: 5-February 03 From: San Antonio, TX Member No.: 247 |
Mike,
have someone push in the clutch while you lookat the spot the tube comes out of the firewall. It rusts loose there and bneds with pressure even though further foward in the tunnel the tube is still attatched. Ed |
cha914 |
Feb 10 2003, 05:38 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
This happened to me and I had to go in and put a shim under the shift fork pivot ball...
sucks cause you have to drop the tranny, but would be better than a loose clutch tube (IMG:style_emoticons/default/tongue.gif) good luck, Tony |
a914luvr |
Feb 11 2003, 12:03 AM
Member Group: Members Posts: 313 Joined: 6-February 03 From: Riverside, CA Member No.: 259 |
ya, Tony's prolly right. See if the throw out arm is hitting the tranny case when the pedal is pushed in. As part of a clutch job I always throw a shim (sometimes 2) under the pivot ball unless I'm using a brand new flywheel.
Lo-Fi Version | Time is now: 13th June 2024 - 04:34 AM |
