Removing targa chrome, ??????Hidden bolts???? |
computers4kids |
Oct 30 2005, 09:27 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I would like to remove the pieces that are connected to the roll bar which the targa top seal rests on. I have removed the vertical pieces that lead up them. How is this piece connected? I don't want to make the same mistake I did when removing the sail piece...you know the hidden bolt.
I would also like to remove the thin piece of chrome at the base of the vinyl for the sides of the roll bar. Much appreciated, |
SLITS |
Oct 30 2005, 09:31 AM
No bolts....just clips...it pulls off
The sail panel trim....would be nice to have a pair of real thin needle nose pliers to compress the spring clips...or a tool that would do it to avoid bending the thin strip. |
boxstr |
Oct 30 2005, 11:12 AM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
The two targa bar vertical pieces are available, $150.oo each. The narrow side pieces are also available $20.00 each, save the little clips if they are not rusted and broken.
CCLINCLIPJOINT |
Porsche Rescue |
Oct 30 2005, 12:04 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Are you referring to the two pieces, one on each side at the top of the bar which run fore and aft (about 6" long)? If so, a small phillips screw on each end holds them on. The long piece across the rear of the bar just pulls off directly to the rear.
Eric_Shea |
Oct 30 2005, 01:05 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Pieces? Slits is right based upon your description of the top seal resting place. It's only one piece though. Pry it off once the verticals are off. |
computers4kids |
Oct 30 2005, 07:44 PM
Thanks for the advice. I just didn't want to tug on the long targa chrome piece and mangle it. It's marred up already a bit from the rubber seal somehow but might polish out.
Thanks again |
Lo-Fi Version | Time is now: 11th June 2024 - 02:51 AM |
