Rear Springs...., hot to tell what I have? |
smooth_eddy |
Oct 30 2005, 04:16 PM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
Last summer I changed my front inserts to Bilstein. Now it is time to change the rear and finally get rid of the KYB's. How do I tell which springs are on the car? And how do I tell if they are worn out or still okay? I only use the car for street, so I am looking for the best possible ride with Bilsteins all the way around. At this time I don't have any sway bars, but plan to install them up front this next Spring when I pull my gas tank. I saw a thread last week and seemed like the 140 lb springs were what were recomended for street use. From the Tech Tips book, Geo says 140's are for the serious A-Xer's. Oh by the way, did a search and could not find the answers. Thanks, Eddy
dlo914 |
Oct 30 2005, 04:45 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
ive got 140 weltmeisters on my driver and it's not stiff at all. My setup for the rear is w/ the bilstein 5 adjustable settings. serious AX'ers would prolly be using 160s, 180s and so on... |
Eric_Shea |
Oct 30 2005, 05:05 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Color coded stripes sprayed on the springs. Look for: Green = Stock 914 Yellow = Stock 914-6 (Someone correct me if I'm wrong. It should be in that book you have.) I like 100lb for only street use. |
d914 |
Oct 30 2005, 05:10 PM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
stocks are real long and will tension still on them at full droop. 100lbs ones I believe will also still have tension at full droop. Both will be able to be compressed some by hand. 140's and higher will tend to be shorter in height so at full droop they would not be compressed by the car....General rule of thumb use with care>>>>
Besides lucking out and having the LBS inscribed on the spring, spring tester is the only way to confirm that i know of.. |
xitspd |
Oct 30 2005, 05:39 PM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
10 inch x 400 pounds x .250 inch
Aaron Cox |
Oct 30 2005, 05:50 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
currently have 180's... going to 225's on threaded perches.
Bleyseng |
Oct 30 2005, 07:32 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Yup, coilovers are the hot ticket. I am running 200# springs now.
140's or 180's are fine even for the crappy Seattle streets as good shocks vs KYB's make alot of difference. Attached thumbnail(s) |
smooth_eddy |
Oct 30 2005, 08:04 PM
I have no idea what this means...............Eddy |
Aaron Cox |
Oct 30 2005, 08:24 PM
10" length, 2.5" ID , 400lb in rating. racin' springs |
xitspd |
Oct 30 2005, 10:46 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Bleyseng |
Oct 30 2005, 11:28 PM
I mite too stiff for a street car, me thinks! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 03:11 PM |
